And so it begins...
railsquid
Helps when you live on top of the prototype ;). I've been spending the last few weeks staring at road markings, crossing barriers, lineside equipment, utility poles etc. (as well as investigating traffic light arrangements for crossroads straddling a level crossing).
For the record this short stretch of the road will eventually turn (behind the camera) turn sharply and go up a steep hill. When I get that far.
  On 2/7/2016 at 3:10 AM, JR 500系 said:
Those wordings look nice! Are they printed (custom made) or did they come with a decal sheet for the shed?  :)
They came from another Tomytec building kit; I just stuck them on some 0.3mm plastic sheet before cutting them out and sticking them to the shed.
That's one of the nice things about Tomytec kits in particular, they come with a bunch of extra decals and parts which can be used "creatively" :)
While tidying up I found a bunch of trees I'd forgotten about, which very nicely disguise the shelf support in the corner.
Close up they do look a bit naff, but from a distance (and that's pretty much the only way to view that corner) they look fine and even help the two backscenes (from completely different locations) blend together.
I didn't see the shelf support at first, but was amazed at how it indeed nicely blends with the backscenes.
Looks good !
Thought that might be interesting, as it's illuminated and Tomytec went to the trouble of decorating the inside.
The camera isn't bad for the price, but the lense is skewed so you have to mount it at an angle.
I also found out the video editing software can crop the picture, which helps remove part of the view of the shelving, and puts it into a better aspect ratio (must experiment more).
Ladies and Gentlemen... I present you a self-referential backscene... One of those houses is Chez Squid, containing this layout. So if you had CSI-style zoom capability, you could zoom in and see the layout, then zoom in on the backscene, and so on ad-infinitum.
There's an apartment block going up not so far away, and evidently they sent up a drone or something to photograph the prospective view from the upper storeys, which they put in a leaflet they've been spamming the neigbourhood with, which happened to include - if you know where to look - my very own domicile. I've literally just cut out the picture and stuck it on, but I'll scan it in and merge it into the existing backscene image better.
OK, it's just a streetlamp, but it means I finally got round to installing it (a messy process involving blobs of solder and repurposed rails). More to follow...
The "classic" terminal blocks don't seem to be available here, the closest I've found are some for higher voltages which you can't cut apart, and other fancy-looking but expensive/impractical products. Still, good soldering practice.
Meanwhile, tools gibbered and wood cringed, for RailSquid is in full-on bodge mode, hijacking the unused main layout boards as a temporary cutting bench. I wonder what it will turn out to be?
Edited by railsquid
Control Panel???
Give that man a senbei!
While the glue is drying, I took part of the road out for a change of scenery.
However the "no parking" sign has not dissuaded the removals van from parking where it wants to.
The control panel emerges from a pile of scrap wood... people with actual woodworking and electronics skills should look away.
looking good. Just make sure you leave enough room around your switches for the underneath part when switches are close to each other (been there, done that)
There should be enough space, though no doubt I will find out sooner or later what fundamental booboo I've made.
Now to remember which wires power which section and replace this with something a little more conventional.
Sorry but I couldn't understand about this... What exactly does this do? Looks interesting...
I've divided the layout into a number of isolated sections so I can park more than one train on the same stretch of track. However I didn't have time to build the control panel with the switches, so soldered all the section wires to a convenient connector, a spare piece of track... Ultimately each of those red wires will be connected to a switch.
