gavino200 Posted February 19, 2022 Share Posted February 19, 2022 It's a noticeable improvement. I especially like the painted insulators. 1 Link to comment
railsquid Posted February 19, 2022 Author Share Posted February 19, 2022 Hah, those are actually still the original plastic, I'll paint those next. Link to comment
gavino200 Posted February 19, 2022 Share Posted February 19, 2022 Ah, so they are. I can see that when I zoom in! It's really quite a big difference in shade. I bet they'll look even better when painted. Link to comment
railsquid Posted February 20, 2022 Author Share Posted February 20, 2022 (edited) No painting so far today, but some concrete "weathering": bridge-support-weathered-2022-02-20_01 by Rail Squid, on Flickr Basically roughened up the surface of the plastic Tomix bridge support with some coarse sandpaper and applied some Tamiya "Panel Line Accent Colour". Works well enough methinks. Edited February 20, 2022 by railsquid 5 Link to comment
Madsing Posted February 20, 2022 Share Posted February 20, 2022 5 hours ago, railsquid said: Works well enough methinks. More than that. It's really nice! Link to comment
Brennan91 Posted February 20, 2022 Share Posted February 20, 2022 On 2/9/2022 at 6:51 PM, railsquid said: A very small amount of work progressed: depot-rear-end-2022-02-09_02 by Rail Squid, on Flickr I’ve seen your 145 series a couple of times in your layout building pictures, and I just realized that you have the full cab version (or whatever it would be called) since the one I found on Tomytec has this kind of truck bed. Also I am curious what the train in the repair building is. Link to comment
railsquid Posted February 20, 2022 Author Share Posted February 20, 2022 Actually that's a MicroAce KuMoYa 143. The one in the shed is a KuMoNi 83-800: Kato KuMoNi 83-800 (83803) by Rail Squid, on Flickr 2 Link to comment
Brennan91 Posted February 21, 2022 Share Posted February 21, 2022 Ah okay, thank you! Link to comment
railsquid Posted May 3, 2022 Author Share Posted May 3, 2022 (edited) Today we perform a long-overdue experiment in expanding provision of invisible overhead wiring so that pantographs are not waving about uselessly in the air: catenary-mast-2022-05-03_02 by Rail Squid, on Flickr Specifically the catenary masts need to be mounted in such a way that they are easily removable; the experiment involves 5mm plastic tubing with holes drilled in the centre to accept the poles: catenary-mast-2022-05-03_01 by Rail Squid, on Flickr Seems to work quite well. Edited May 3, 2022 by railsquid line jump 2 Link to comment
cteno4 Posted May 3, 2022 Share Posted May 3, 2022 The invisible catenary wire is quite impressive squid! Rarely see that level of detail. jeff 2 Link to comment
railsquid Posted May 4, 2022 Author Share Posted May 4, 2022 On 2/10/2022 at 8:51 AM, railsquid said: And a little shelter for random unidentified barrels: depot-rear-end-2022-02-09_01 by Rail Squid, on Flickr More barrels'n'stuff added: depot-rear-2022-05-04_01 by Rail Squid, on Flickr 6 Link to comment
railsquid Posted May 5, 2022 Author Share Posted May 5, 2022 (edited) Next up: some arrangement for the side of the depot where there's long been a large Triangle of Indecision. Something like this seems to work: depot-side-expansion-2022-05-05_01 by Rail Squid, on Flickr so out with the Tamiya foamboard: depot-side-expansion-2022-05-05_02 by Rail Squid, on Flickr then off to the shops for some more bit of wall, as I don't quite have enough... Edited May 6, 2022 by railsquid typo 2 Link to comment
railsquid Posted May 6, 2022 Author Share Posted May 6, 2022 Triangle of Indecision now fully surfaced: depot-side-expansion-2022-05-06_01 by Rail Squid, on Flickr 5 Link to comment
Madsing Posted May 6, 2022 Share Posted May 6, 2022 Nice! Now you have to decide what to put there, and rename the triangle 😜 Link to comment
cteno4 Posted May 6, 2022 Share Posted May 6, 2022 Where was the documentation of the payment crew?! jeff Link to comment
railsquid Posted May 7, 2022 Author Share Posted May 7, 2022 Depot wall provisionally installed: depot-side-expansion-2022-05-07_03 by Rail Squid, on Flickr depot-side-expansion-2022-05-07_01 by Rail Squid, on Flickr depot-side-expansion-2022-05-07_02 by Rail Squid, on Flickr 8 Link to comment
railsquid Posted May 8, 2022 Author Share Posted May 8, 2022 Side gate under construction... depot-side-expansion-2022-05-08_01 by Rail Squid, on Flickr 6 Link to comment
railsquid Posted May 8, 2022 Author Share Posted May 8, 2022 Meanwhile, while various other bits drying, provisional placement of some catenary end masts: depot-rear-2022-05-08_01 by Rail Squid, on Flickr Will need painting etc. 7 Link to comment
railsquid Posted May 17, 2022 Author Share Posted May 17, 2022 (edited) A bit more work around the edge of the depot: depot-side-expansion-2022-05-17_01 by Rail Squid, on Flickr depot-side-expansion-2022-05-17_02 by Rail Squid, on Flickr Edited May 17, 2022 by railsquid 11 Link to comment
railsquid Posted May 21, 2022 Author Share Posted May 21, 2022 Random view: depot-view-2022-05-21_01 by Rail Squid, on Flickr mainly because I am pootling around sorting out another "problem" area, that around the brick arched viaduct. 10 Link to comment
railsquid Posted June 12, 2022 Author Share Posted June 12, 2022 (edited) Slowly getting around to finishing the top of the concrete-ish viaduct section above, which used to look like this: front-left-concrete-viaduct-2020-07-08_01 by Rail Squid, on Flickr Now: upper-loop-transition-piece-2022-06-12_02 by Rail Squid, on Flickr Need to ballast in the gaps but a susbstantial improvement over the preceding bare plywood and cardboard shims look. Edited June 12, 2022 by railsquid 10 Link to comment
railsquid Posted June 16, 2022 Author Share Posted June 16, 2022 Gaps mainly ballasted-in: upper-loop-transition-piece-2022-06-12_03 by Rail Squid, on Flickr upper-loop-transition-piece-2022-06-13_01 by Rail Squid, on Flickr upper-loop-transition-piece-2022-06-15_01 by Rail Squid, on Flickr 8 Link to comment
railsquid Posted June 17, 2022 Author Share Posted June 17, 2022 Expanding the cable trunking a little: upper-loop-transition-piece-2022-06-17_01 by Rail Squid, on Flickr 3 Link to comment
railsquid Posted June 17, 2022 Author Share Posted June 17, 2022 And because it's Friday night and I know how to party, here's another trunking section being installed with the aid of some Kato track pins (get a lot of use out of those, I do): upper-loop-station-right-end-2022-06-17_01 by Rail Squid, on Flickr so the Random Equipment Boxes look like they are connected to something. 6 Link to comment
railsquid Posted June 18, 2022 Author Share Posted June 18, 2022 (edited) It's surprising how much fencing and railing a layout can swallow up... upper-loop-fence-section-2022-06-18_01 by [url=https://www.flickr.com/photos/railsquid/]Rail Squid[/url], on Flickr Not going win any prizes for fine scale modelling, but looks OK from normal viewing distance. Edited June 18, 2022 by railsquid 4 Link to comment
