Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:09 PM, inobu said: Will it bow downward when you turn it up right? Expand @inobuno Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 Look for heat or scorching. You said you smelled something. Either it is the pick ups or light board. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:13 PM, inobu said: Look for heat or scorching. You said you smelled something. Either it is the pick ups or light board. Expand The smell came from the powerpack after the whole system shut down when the faulty motor car was on the rails, and the speed turned to maximum and the powerpack shut off. I reset the powerpack and everything turned normal. I noticed a very slight heating from the power bogies I think. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:15 PM, Daniel C said: The smell came from the powerpack after the whole system shut down when the faulty motor car was on the rails, and the speed turned to maximum and the powerpack shut off. I reset the powerpack and everything turned normal. I noticed a very slight heating from the power bogies I think. Expand the power car is still faulty I mean Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:16 PM, inobu said: Your other trains work ok? Expand Yes, both Kato and Tomix of varying speeds and sizes Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 You need to check the light board. The power flow is track to wheels to pickup to board Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:21 PM, inobu said: You need to check the light board. The power flow is track to wheels to pickup to board Expand what does a faulty light board look like? Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:22 PM, Daniel C said: what does a faulty light board look like? Expand I mean even if I put the powercar by itself on the rails with power on it does not move Link to comment
disturbman Posted March 17, 2021 Share Posted March 17, 2021 If the lightboards are faulty, shouldn't the short be replicated by just putting the lead cars on the rails, without the motor car? If there is heat in the power bogies of the motor car, the short is probably happening there. Not the lead cars. Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 The light board also feeds the motor Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:24 PM, inobu said: The light board also feeds the motor Expand I assume this would happen in a locomotive or a DMU/EMU with the cab and motor in the same car such as a JR East 701 series or KiHa 110 series. This is not the case with mine I guess. Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 I'm using the light board term loosely. The board that feeds the motor Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:24 PM, disturbman said: If the lightboards are faulty, shouldn't the short be replicated by just putting the lead cars on the rails, without the motor car? If there is heat in the power bogies of the motor car, the short is probably happening there. Not the lead cars. Expand Any diagnostic tests for this? and how does one disassemble the bogies for inspection? I mean, literally taking them apart. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:27 PM, inobu said: I'm using the light board term loosely. The board that feeds the motor Expand Oh I see. Where can I find that? Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 Does that motor car have lights in the roof? Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 @disturbmanI think it's not the bogies. I removed the entire motor unit and only attached the bogies and nothing happened to the powerpack or the leading cars. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:36 PM, inobu said: Does that motor car have lights in the roof? Expand no, just the ordinary power car that Kato would make for their lineup of commuter trains (no inspection equipment lighting gimmick or interior lighting) Link to comment
disturbman Posted March 17, 2021 Share Posted March 17, 2021 I didn't meant the boggies, I meant the motor car. Metal is very conductive to heat. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:37 PM, Daniel C said: @disturbmanI think it's not the bogies. I removed the entire motor unit and only attached the bogies and nothing happened to the powerpack or the leading cars. Expand @inobuWhen I try pressing the copper strips attached to the motor to the rails the motor works! Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:39 PM, disturbman said: I didn't meant the boggies, I meant the motor car. Metal is very conductive to heat. Expand Yes I meant the power bogies attached to the power car underframe Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 ok, its the poor connection that is drawing the high current. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:41 PM, inobu said: ok, its the poor connection that is drawing the high current. Expand you mean the contact shoes in the bogies and the strips in the underframe? Link to comment
inobu Posted March 17, 2021 Share Posted March 17, 2021 On 3/17/2021 at 10:43 PM, Daniel C said: you mean the contact shoes in the bogies and the strips in the underframe? Expand you touched these right. Link to comment
Daniel C Posted March 17, 2021 Author Share Posted March 17, 2021 On 3/17/2021 at 10:47 PM, inobu said: you touched these right. Expand What do you mean? Link to comment
