railsquid Posted December 24, 2022 Author Share Posted December 24, 2022 Festively random seasonal greetings! 9 Link to comment
cteno4 Posted December 25, 2022 Share Posted December 25, 2022 Hey, Squid has his own painted train! Like I’ve said many times: “Any train with a Cephalopod on it is a good train!” Cephalopods rule! jeff 5 2 Link to comment
railsquid Posted December 26, 2022 Author Share Posted December 26, 2022 (edited) Meanwhile, no rest for the wicked. The depot staff have been complaining about the lack of surfaced walkways connecting the different areas of the depot, so taking advantage of a lull in traffic the contractors have been busy. depot-area-2022-12-26_01 by Rail Squid, on Flickr Edited December 26, 2022 by railsquid 5 Link to comment
railsquid Posted April 30, 2023 Author Share Posted April 30, 2023 Right, 5 years on since the last tabula rasa, I will have to dismantle it all due to the A/C unit above the layout needing to be replaced. This has always been a possibility so the dismantling will be largely non-destructive. Unfortunately this time round I'm not sure if I will get round to reassembling it, as That Virus™ came visiting earlier this year and I am still suffering the after-effects... 1 6 Link to comment
railsquid Posted April 30, 2023 Author Share Posted April 30, 2023 Though on reflection in the surface of a nice hot bath, I think what I could do is convert it into a dogbone around the available edges of the room, mainly ca. 30cm deep except for the end curves, which would also free up a bit of space in the room, though part of it would have to run behind my work desk. 3 Link to comment
Beaver Posted April 30, 2023 Share Posted April 30, 2023 I like that idea. More realistic appearance with a real sense of journey. You could have central Tokyo at one end and the valleys of Yamanashi at the other end! Around a foot deep is in my experience about right for a long thin layout. Deep enough for complex trackwork and scenery that isn't just a transect line, shallow enough to be easily portable and restrained in volume. To be honest a shallow layout can actually look more realistic than a deep one, perhaps because it's obviously not a stereotypical train set rectangle. The only obvious issue is that the up and down lines will be at opposite polarities since they are basically opposite sides of a single track loop. So creating crossovers between them or loops and sidings that connect to both could be tricky. Unless you wire the end curves as reversing loops........ Link to comment
ianlaw Posted April 30, 2023 Share Posted April 30, 2023 One thing to note with a shallow layout is that you won't be able to get good photos if the track is too close to the edge. I'm adding 10cm here and there to the front now just for that reason. 1 Link to comment
railsquid Posted May 7, 2023 Author Share Posted May 7, 2023 Scenes of destruction: takahachikawa-2023-05-07_01 by Rail Squid, on Flickr But this is what one end of the dogbone could look like, reusing some of the existing scenic infrastructure: takahachikawa-2023-05-07_02 by Rail Squid, on Flickr After a bit of consideration I will make the layout 60cm deep along the full-length wall, as the baseboards are 60x90 and that way I will have less to cut. 4 3 Link to comment
ianlaw Posted May 7, 2023 Share Posted May 7, 2023 My shelf/ dogbone layout is also 60cm deep and can reach everywhere. Obviously the return loops for the shinkansen have to be wider. And I'm adding 10cm at certain locations to enable better photography. I do however have to fit 2x2 tracks and where the diesel line splits 3x2 tracks. Link to comment
railsquid Posted May 14, 2023 Author Share Posted May 14, 2023 Almost exactly 5 years ago: reconstruction_001 by Rail Squid, on Flickr Today, WIP: takahachikawa-2023-05-14_01 by Rail Squid, on Flickr I think I have hit on a way of holding all the flat woody bits in place against the siren call of gravity which involves cutting just 4 pieces of wood and no thick paperback books. 7 Link to comment
railsquid Posted June 25, 2023 Author Share Posted June 25, 2023 (edited) So... first flat woody bit more-or-less fixed in place (part of the brilliant idea is to fix some of the supports to the wall rather than the previous free-standing frame), and good enough excuse to run a train for the first time in yonks, which especially for the occasion is the Kato "Kokuden" unit which was the thing which is responsible for my descent into borderline train hoarder some 9 years ago). Work-in-progress... by Rail Squid, on Flickr Edited June 25, 2023 by railsquid 6 Link to comment
railsquid Posted July 1, 2023 Author Share Posted July 1, 2023 (edited) And the next bit is in place: takahachikawa-2023-07-01_01 by Rail Squid, on Flickr Not going to win any woodworking prizes, but turned out better than I hoped, and gives me some room to maneuver while I work out how to rearrange everything. Edited July 1, 2023 by railsquid 4 Link to comment
railsquid Posted July 2, 2023 Author Share Posted July 2, 2023 A side-effect of this is that I've been motivated to tidy up the under-layout storage, and have finally organised the Chuo Line full-size bookcases into a single contiguous section (lower part of the shelving units): 6 Link to comment
railsquid Posted August 8, 2023 Author Share Posted August 8, 2023 And some actual progress after a long interlude... takahachikawa-2023-08-08_01 by Rail Squid, on Flickr The scenery will be modified in due course. 8 Link to comment
railsquid Posted August 11, 2023 Author Share Posted August 11, 2023 The scenery being modified in due course: takahachikawa-2023-08-11_01 by Rail Squid, on Flickr 5 Link to comment
cteno4 Posted August 11, 2023 Share Posted August 11, 2023 Where are the chopsticks? jeff 1 Link to comment
railsquid Posted August 11, 2023 Author Share Posted August 11, 2023 2 minutes ago, cteno4 said: Where are the chopsticks? Some are partly exposed between the centre and right-hand tunnel mouths. I was thinking to myself as I squid-handled the section back-and-forth twixt layout and workbench that the structure has proven nice and solid. 3 Link to comment
cteno4 Posted August 11, 2023 Share Posted August 11, 2023 Ahh I see em! They really are a great material. I have a big box of them (even though we always ask for no chopsticks, they just can’t do take away without chopsticks!) that I use for all sorts of things in the shop, but I need to start using them on train stuff! jeff 1 Link to comment
railsquid Posted August 12, 2023 Author Share Posted August 12, 2023 More chopstick exposure for anyone interested: takahachikawa-2023-08-12_01 by Rail Squid, on Flickr Turns out I need to realign the inner curve so ripped out the tunnel. Don't try this in real life though, folks. 7 Link to comment
railsquid Posted August 13, 2023 Author Share Posted August 13, 2023 Once again the high plains of western Tokyo have echoed to the banshee wails of the bodgeridoo, and as if by magic a corner section has appeared: takahachikawa-2023-08-13_01 by Rail Squid, on Flickr 8 Link to comment
railsquid Posted August 15, 2023 Author Share Posted August 15, 2023 In today's slow march of progress, we stress-test the connecting gradient between lower and upper loops, using British motive power as it usually lacks traction tyres: takahachikawa-2023-08-15_01 by Rail Squid, on Flickr Went better than I thought, apart from the tendency of Dapol coaches to uncouple themselves at the slightest unevenness of track. 4 Link to comment
cteno4 Posted August 15, 2023 Share Posted August 15, 2023 1 hour ago, railsquid said: apart from the tendency of Dapol coaches to uncouple themselves at the slightest unevenness of track. Makes them good test cars! jeff Link to comment
railsquid Posted August 26, 2023 Author Share Posted August 26, 2023 Time for some chopstickery again: takahachikawa-2023-08-26_01 by Rail Squid, on Flickr Need to expand a bit of hillside. Tunnel mouth placed temporarily while I work out how which bit of scenery to fix it to. 4 1 Link to comment
cteno4 Posted August 26, 2023 Share Posted August 26, 2023 chopstickery, I like it! jeff 1 Link to comment
railsquid Posted August 26, 2023 Author Share Posted August 26, 2023 Chop chop, stick stick: takahachikawa-2023-08-26_02 by Rail Squid, on Flickr 6 1 Link to comment
