Blobby Posted January 31, 2016 Author Share Posted January 31, 2016 (edited) I've decided to go with the track plan being used nickhp for a b train layout: http://www.jnsforum.com/community/topic/7889-b-train-layout/page-4 KVP kindly scaled it up using Tomix track for me so that I can use normal length cars, the extra track I need has been despatched from ModelTrain plus. I will add some track so that the layout can be extended to another board at a later date. I would also like to add some viaduct track but haven't decided what yet incidentally the track plan seems to have come from this blog: http://blogs.yahoo.co.jp/jt2004sky/folder/60238.html?m=lc&p=1 it's well worth a look at as it has tons of interesting bits on it Edited January 31, 2016 by Blobby Link to comment
Blobby Posted December 15, 2016 Author Share Posted December 15, 2016 Has anybody used polyurethane foam for baseboard construction? If so how did you fix tomix/kato track to the foam`? Link to comment
Guest Closed Account 1 Posted December 15, 2016 Share Posted December 15, 2016 (edited) Has anybody used polyurethane foam for baseboard construction? If so how did you fix tomix/kato track to the foam`? I just cut the blue foam sheets 2x8, to fit the 1x3" structure, and wood glue them together. Drill holes in the foam for the wiring and slip a cheap drinking straw in the hole to prevent the hole from closing. I use white glue to adhere the snap track to the foam. Edited December 15, 2016 by Webskipper Link to comment
Blobby Posted December 20, 2016 Author Share Posted December 20, 2016 I just cut the blue foam sheets 2x8, to fit the 1x3" structure, and wood glue them together. Drill holes in the foam for the wiring and slip a cheap drinking straw in the hole to prevent the hole from closing. I use white glue to adhere the snap track to the foam. Thanx for thta webskipper Link to comment
