lurkingknight Posted October 6, 2014 Share Posted October 6, 2014 lol this tweet just showed up in my feed: https://twitter.com/izaizawotagei/status/518902878254006272 1 Link to comment
ozman2009 Posted October 6, 2014 Share Posted October 6, 2014 Someone's had a bit of rain! LOL Link to comment
railsquid Posted October 6, 2014 Share Posted October 6, 2014 Typhoon blowing through at the moment. Link to comment
miyakoji Posted October 6, 2014 Share Posted October 6, 2014 Looks like one that I think Toni posted before. Is that station really prone to flooding? I'm surprised they don't do something about that. No guarantee the electrical equipment is going to survive that. Link to comment
bikkuri bahn Posted October 6, 2014 Share Posted October 6, 2014 That picture looks suspiciously like the one posted before (last year). This one looks more legit: https://twitter.com/HGTK_R/status/518919669793583105/photo/1 Link to comment
bikkuri bahn Posted October 6, 2014 Share Posted October 6, 2014 FWIW, Shin Keisei's website is reporting delays in their services, along with some cancellations and the suspension of through services on the Keisei Line. No closures. Link to comment
railsquid Posted October 6, 2014 Share Posted October 6, 2014 (edited) Typhoon has passed (wasn't very dramatic, at least here on the west side of Tokyo) and is now back out to sea. Still a few line closures in areas closer to the sea. Edited October 6, 2014 by railsquid Link to comment
katoftw Posted October 6, 2014 Share Posted October 6, 2014 surprized the wheel can pass current to the track in a pool of water. Link to comment
lurkingknight Posted October 6, 2014 Author Share Posted October 6, 2014 is that not an overhead powered train? I see overhead lines. Link to comment
railsquid Posted October 6, 2014 Share Posted October 6, 2014 The current has to go somewhere once it's passed through the pantograph. Link to comment
Mudkip Orange Posted October 6, 2014 Share Posted October 6, 2014 Seeing as how water conducts, I really doubt that grounding is a problem... Link to comment
kvp Posted October 6, 2014 Share Posted October 6, 2014 Deep water can happen above concrete slab tracks when the drainage system has way less capacity than the amount of rainwater coming in. Usualy once the heay rain stops, the water slowly drains away. A tram track example: Also, in the US the New York city subway is actually used as a semi official rainwater collection system. Of course, they have the right equipment to pump everything out. Link to comment
katoftw Posted October 7, 2014 Share Posted October 7, 2014 On 10/6/2014 at 4:16 PM, Mudkip Orange said: Seeing as how water conducts, I really doubt that grounding is a problem... correct. but the water is everywhere. grounding to incorrect locations is deadly to electrical circuits. Link to comment
kvp Posted October 7, 2014 Share Posted October 7, 2014 Quote correct. but the water is everywhere. grounding to incorrect locations is deadly to electrical circuits. Electricity will take the easiest path. As far as i know the least resistance is offered by the metal running rails. Other than that, there could be places where the water creates a shorter path somewhere else, but it won't really affect the train, just lineside equipment and anything in the vicinity not properly protected against lighting strikes. If left for a long time, there could be electric corrosion on metal parts that get connected into the circuit. If there is a serious leak of electric power or a ground fault is detected, then the substation would turn off the power anyway. In the London underground, many lines have isolated 4th rails, that act as a current return, because when routed through the running rails, electricity tends to go into the ground through the old cast iron tube walls and that would cause corrosion. Other than that, the trains would run just as well with an earth return. Many older rural lines have a single wire and use this earth return for normal operation. http://en.wikipedia.org/wiki/Single-wire_earth_return Link to comment
lurkingknight Posted October 7, 2014 Author Share Posted October 7, 2014 path of least resistance would still be metal to metal contact, water by itself is not that conductive. could be wrong though. On 10/6/2014 at 3:15 PM, railsquid said: The current has to go somewhere once it's passed through the pantograph. Link to comment
