Sascha Posted October 3, 2014 Share Posted October 3, 2014 I'm confused. What is the difference between a A; Curved Superelevated Track B: Curved Superelevated Track (concrete sleepers), and C: Double Wooden Sleeper Curved Track. The only difference I could find, seemed to be in a slightly different color. And when would I use the A: Concrete Tie Double Track and the B: Concrete Slap Double Track? I'm planing on having an elevated Shinkansen track above my ground level track, and a Underground (Subway) line. Any help is as always greatly appreciated. Sascha Link to comment
kvp Posted October 3, 2014 Share Posted October 3, 2014 A; Curved Superelevated Track: superelevated with wooden pattern sleepers, the choice for old mainlines B: Curved Superelevated Track (concrete sleepers): superelevated with solid concrete sleepers, the choice for modern mainlines C: Double Wooden Sleeper Curved Track: completly flat (not superelevated) and wooden pattern sleepers A and B needs transition pieces from flat to superelevation and back and can't be used safely for S curves, C can be used anywhere. A: Concrete Tie Double Track: classic track with concrete ties and ballast B: Concrete Slap Double Track: slab track without ties or ballast, seen on some new shinkansen lines The second one is modern buy rarely used and almost always on viaducts and elevated stations. 1 Link to comment
katoftw Posted October 3, 2014 Share Posted October 3, 2014 (edited) double wood tracks do not exsist from any manufacturer. most shinkansen lines are slab type. but if you are using kato, they do not offer S248 or R481 in slab. so if you want to keep it all uniform looking, then concrete ties is a better option. Edited October 3, 2014 by katoftw 1 Link to comment
Sascha Posted October 3, 2014 Author Share Posted October 3, 2014 Thanks you KVP that was the info I needed. Link to comment
Sascha Posted October 3, 2014 Author Share Posted October 3, 2014 (edited) double wood tracks do not exsist from any manufacturer. . I did found them on Amazon while searching for the other two, but maybe its the wrong name on the page. http://www.amazon.com/Kato-20-112-Double-Wooden-Sleeper/dp/B0003K3IHO Edited October 3, 2014 by Sascha Link to comment
The Next Station Is... Posted October 3, 2014 Share Posted October 3, 2014 I did found them on Amazon while searching for the other two, but maybe its the wrong name on the page. http://www.amazon.com/Kato-20-112-Double-Wooden-Sleeper/dp/B0003K3IHO I believe it's now discontinued but Kato did produce these single wooden track curves pre-mounted on double track bases, although I believe you can take them off those bases as well. Link to comment
katoftw Posted October 3, 2014 Share Posted October 3, 2014 Yes my apologies. I forgot about those. They didn't even come into my mind when I read your question. I wouldn't recommend them as they are hard to get, and you may be left with options that you are unable to do. Link to comment
Mudkip Orange Posted October 3, 2014 Share Posted October 3, 2014 Yeah, stay away from the plate system if you can. Either stick with singletrack or embrace the concrete tie revolucione Link to comment
Krackel Hopper Posted October 3, 2014 Share Posted October 3, 2014 Yes my apologies. I forgot about those. They didn't even come into my mind when I read your question. I wouldn't recommend them as they are hard to get, and you may be left with options that you are unable to do. They are just standard 282/315 curves fitted into a scenery plate. They are perfectly compatible with standard kato track and can be used interchangeably. They are a great option to dress up certain areas of your layout. They are discontinued and availability can be spotty.. often I see these at local train swap meets for dirt cheap.. I would not discourage anyone from using these as they have a lot of potential for great scenes. Link to comment
