bill937ca Posted June 6, 2017 Share Posted June 6, 2017 On 6/6/2017 at 11:16 AM, Pauljag900 said: Cheers bill, R280 it is then as I want the tram tracks to look like one piece with three tracks built into it,like this, IMG_1832.JPG So does that look about right to you mate? Looks good, Paul. Link to comment
Pauljag900 Posted June 6, 2017 Author Share Posted June 6, 2017 Thanks a lot bill,really appreciate that mate 1 Link to comment
bill937ca Posted June 6, 2017 Share Posted June 6, 2017 You may have an issue with the corner of the R280-15 clipping the stone straights when you try to assemble them. This happens with Wide Tram Track also at turnouts. Link to comment
Pauljag900 Posted June 6, 2017 Author Share Posted June 6, 2017 Hi bill I assume you mean the center straight of tram track?if so,and it does clip it I ll use a 70mm train track and the same at the points,or I may just clip the corner off the tram to accommodate it.i m assuming you ve come across this before,what did you do? .Thanks mate Link to comment
kvp Posted June 6, 2017 Share Posted June 6, 2017 With the 280 mm curves, the straight tram tracks will also clip each other as the track to track distance will be less than 37mm. Link to comment
Pauljag900 Posted June 6, 2017 Author Share Posted June 6, 2017 Hi kvp, What radius do you think will give the correct spacing to have the 3 tram track fixed together? Link to comment
bill937ca Posted June 6, 2017 Share Posted June 6, 2017 On 6/6/2017 at 11:41 AM, Pauljag900 said: Hi bill I assume you mean the center straight of tram track?if so,and it does clip it I ll use a 70mm train track and the same at the points,or I may just clip the corner off the tram to accommodate it.i m assuming you ve come across this before,what did you do? .Thanks mate Yes, I have. Link to comment
kvp Posted June 7, 2017 Share Posted June 7, 2017 On 6/6/2017 at 11:55 AM, Pauljag900 said: Hi kvp, What radius do you think will give the correct spacing to have the 3 tram track fixed together? 541 mm. In a track planner, the correct track to track distance could be checked easily by using the 37mm crossing pieces as guides. Link to comment
Pauljag900 Posted June 7, 2017 Author Share Posted June 7, 2017 Cheers kvp.From the info bill937ca gave me yesterday I tried it on anyrail last night and set my grid size to 37mm,the correct width for the tomix tram track,and the 541 is the one that is correct to give 37mm spacing. Cheers for the info Link to comment
