TCS EUN651 problem in a Hobbytrain BR1216
kmcsjr
Folks
I tried installing a TCS NEM in a Hobbytrain BR1216  Part number H2721.
I use an NCE Power Cab.
This is my new favorite loco... But.
When I installed it correctly (I think), it couldn'r read the manufacture CV.
When Iturned the board over, it took off like a shot.
The platine board and the motor pickups are isolated from the frame, except where appropriate. I have the decoder packaged for warranty replacement, but thought I'd post here, in hopes of a better Idea. A reset attempt did not work.
Thanks
Guest Closed Account 1
Can you show us a pic of how the decoder is installed?  Fat square chip should face up.
Try a factory reset and reprogram. Cv8=2 to reset.
Edited by Webskipper
thanks skipper, I rechecked before sending it out. I did have that chip up. It couldn't read CV8, but I put a 2 in anyway. Nothing changed.
What's the update KMCSJR?
I recently installed one of these in a FVM GEVO.
The socket is hidden under the shrink wrapped LED leads so I did not see that one of the decoder pins went its own way.
Runs fine now. Speed matched easily.
