worldrailboy Posted January 9, 2012 Share Posted January 9, 2012 finally found a nice source for train-rated motor but had to check in case anyone knew of others online as well? http://www.nigellawton009.com/6V6mmx10mmMicroMotors.html Link to comment
The_Ghan Posted January 9, 2012 Share Posted January 9, 2012 Crikey! That's less than a 1/4" diameter !!! Cheers The_Ghan Link to comment
cteno4 Posted January 9, 2012 Share Posted January 9, 2012 how about 4mm x 8mm... or 3.2mm x 10mm... also lots of small gears http://www.shop.kkpmo.com/index.php/cat/c31_Small-DC-Motors.html/XTCsid/5e5cdf6bbb2564064a50a31e0b81f79d cheers jeff Link to comment
keitaro Posted January 9, 2012 Share Posted January 9, 2012 the motor from the world kogei are good too example http://www.1999.co.jp/eng/10139109 the motor itself if you don't want to use the rest is roughly 6 x 8mm handles voltages fine Link to comment
worldrailboy Posted January 9, 2012 Author Share Posted January 9, 2012 thanks for these two links, I'll look at them again when I can I could imagine someone who likes to kitbash a lot would maybe try using the 4mm x 8mm motor to repower that pocket line steam locomotive so it finally wouldn't have to be stuck with a coach car all the times :) (might be sensitive for very clean tracks for its quite light with nowwhere to add usual weight pieces inside tho?) Link to comment
jappomania Posted January 9, 2012 Share Posted January 9, 2012 if you have friend with PC or mobile phone store a good source for free motor are broken CD-DVD rom player (carrige motor), vibracall motors inside old mobile phone voltage between 4,5V and 12V, you need to control it but for 0,0$ if you burn something... ciao Massimo Link to comment
Bernard Posted January 9, 2012 Share Posted January 9, 2012 Nice topic.....I think a lot of us are always in the search for small motors. I usually look for old portable cassette players (Walkmans) and take the motors out. Link to comment
worldrailboy Posted January 9, 2012 Author Share Posted January 9, 2012 I was actually thinking of these little motors more for certain removeable trackside buildings (meaning the usual under-board motors wouldn't be so suitable) check my layout thread at http://www.jnsforum.com/index.php/topic,6076.0.html to see one use I might think about trying with these mini motors Link to comment
jappomania Posted January 9, 2012 Share Posted January 9, 2012 and don't forget this one http://www.gizmoszone.com/shopping/agora.cgi?product=Gearmotor;ppinc=1g if you need really slow speed (also you can find one of this motor type inside "spinlash"...) ciao Massimo Link to comment
cteno4 Posted January 9, 2012 Share Posted January 9, 2012 Massimo, sweet, nicely geared down tiny motors, ive got some ideas for those! thanks jeff Link to comment
jappomania Posted January 9, 2012 Share Posted January 9, 2012 Massimo, sweet, nicely geared down tiny motors, ive got some ideas for those! thanks jeff ...... monorail..... Link to comment
keitaro Posted January 9, 2012 Share Posted January 9, 2012 I already got a motor in a monorail. trying to work out best way to power them. Turns out mounting rail to the plastic rail is difficult... Those motors are great for side mounting. hand drill a small hole place the motor through and a small wheel borh sides. Alternatively get working powered trucks and mount rail on the track which is incredibly hard. Link to comment
worldrailboy Posted January 10, 2012 Author Share Posted January 10, 2012 keitaro why don't you look at a few things on http://schucodisneylandmonorail.com/ (facts, photos of the shell opened up to show the motor drive, etc) and see if it'll give you any better insight? Link to comment
keitaro Posted January 10, 2012 Share Posted January 10, 2012 i have seen that. Issue is thats too large for the greenmax monorail kit which allows roughly 10mm inside it. my main issue is however getting power to the unit as there is little room for batteries. I have another idea but i have not had much time of late to do anything with it. i've set aside this project till i can get some more time prob june this year. my wife is going over seas 7 weeks before me to japan. 7 weeks ought to be enough time to set something up. Link to comment
