Guest Closed Account 1 Posted January 7, 2012 Share Posted January 7, 2012 How about replacement trucks? Then coupler height would be within tolerences. Link to comment
to2leo Posted January 7, 2012 Share Posted January 7, 2012 I do not have a better solution to coupling except adding sticky putty between the couplers. The issue with this train set is because of the inconsistent height of the rapido coupler that sits in the European standardize NEM coupler box. Link to comment
keitaro Posted January 7, 2012 Share Posted January 7, 2012 I get this problem on some freight as well does a small trim of cardboard fit under the coupler mount to give it some more height? Link to comment
The_Ghan Posted January 8, 2012 Share Posted January 8, 2012 Cardboard would wear and decompose. Go to Bunnings and get some nylon washers ... even some 0.5mm brass or stainless ones. Cost you $5. Cheers The_Ghan Link to comment
sid21177 Posted January 13, 2012 Share Posted January 13, 2012 Hi, Whats the turning radius on the Re460 loco ?? Will it take 9 3/4" curves (like most kato locos) Link to comment
Tecchan Posted January 15, 2012 Author Share Posted January 15, 2012 Hi, Whats the turning radius on the Re460 loco ?? Will it take 9 3/4" curves (like most kato locos) It runs well on my Tomix 280mm radius, did not try smaller but it would not look good anyway. I doubt that the IC 2000 would enjoy a smaller radius though... Link to comment
to2leo Posted January 15, 2012 Share Posted January 15, 2012 Hi let's just say the loco can even negotiate Kato's R150mm 6" compact curved track better than Modemo's. The Re460 IMHO is the most durable Kato European model that I have ever owned. Link to comment
sid21177 Posted January 16, 2012 Share Posted January 16, 2012 Hi let's just say the loco can even negotiate Kato's R150mm 6" compact curved track better than Modemo's. The Re460 IMHO is the most durable Kato European model that I have ever owned. cool - good pulling power ?? - something like 2x 6421 cleaning cars for example ?? Link to comment
to2leo Posted February 25, 2012 Share Posted February 25, 2012 It has tires so yes, it can pull like no other. Link to comment
Tecchan Posted February 26, 2012 Author Share Posted February 26, 2012 Made a small illustrated blog post on the subject! :-) Thanks for your advices guys! http://tecchan.loriskumo.com/2012/02/fixing-the-hobbytrain-ic2000-double-deckers/ 1 Link to comment
Spaceman Spiff Posted December 17, 2012 Share Posted December 17, 2012 Hey there, I know I'm bumping an old thread. Does anyone have the newer release of these cars. Supposedly H25108 thru to H25112 are 2012 releases. I wonder if the Kato Hobbytrain release addressed the clearance issue? Spiff Link to comment
to2leo Posted December 18, 2012 Share Posted December 18, 2012 Not sure they would address the problem because I got some of my train cars from their 2nd release. This must be their 3rd release? Link to comment
Guest Closed Account 1 Posted December 22, 2012 Share Posted December 22, 2012 Did you get the coaches to work? Are the coaches as low profiled as the Kato E5? That's a tough one to keep on the flex tracks at shows. The tracks have to be true gauge and flat or gentle transitions like Unitrack or Tomix. What's the wheel diameter? 4.1mm is what's common on the Kato Shinkansens. Link to comment
Ochanomizu Posted December 24, 2012 Share Posted December 24, 2012 Kato E5. The problem is because your flex track does not comply with the Standard of Japan. Link to comment
Spaceman Spiff Posted January 20, 2013 Share Posted January 20, 2013 I really like this Hobby train and was really hesitant to get a set due to the issues mentioned. A good deal came by and I took the plunge. The set ran fine on my layout but there were spots (rerailers) where the belly of the coaches would rub but did not uncouple. I ended up using the little spacers provided with Microtrain trucks. I cut the small rings so they would fit on to the circular part of the truck (pic 1). This seems to give enough lift to the coaches so that they dont rub on my layout (pic 2). I have one dedicated car that will be exclusively hooking up to the loco. On that car I left the truck closest to the loco unmodified so there isn't any coupler height issues with the loco. I can also lift the coaches with out worrying about the trucks falling off as the trucks are still securely attached. Spiff Link to comment
