NozomiFan Posted June 21, 2011 Share Posted June 21, 2011 So as the title says, what are the curving of the curves? 381/414? 315/282? I don't know. Also, where are the track plans that are a bit more complicated than the ones on the back of the boxes? Link to comment
David Posted June 21, 2011 Share Posted June 21, 2011 It depends on the set. Clicking on a photo gives you a parts list for each set. http://www.katousa.com/N/Unitrack/mastervar.html Most are 381/414 except for the V14 which is 282/315 and V15 which is not really in the same category. Link to comment
NozomiFan Posted June 21, 2011 Author Share Posted June 21, 2011 Hey guys, another question. I might have a firm layout plan, but I need your help. What are those tan boxes with the Katakana in them? What do they say? Also, what is the grey box next to the controller next to it? Link to comment
bikkuri bahn Posted June 22, 2011 Share Posted June 22, 2011 What are those tan boxes with the Katakana in them? Those are prefab baseboards. what is the grey box next to the controller next to it? Controller for the automated crossing gates. Link to comment
Guest Closed Account 1 Posted June 22, 2011 Share Posted June 22, 2011 Unitrack Plans: http://www.katomodels.com/unitrackplan/ It really is up to how much room you have. Recommend tables under 36 inches wide. Very hard to reach and balance at 36. Link to comment
NozomiFan Posted June 22, 2011 Author Share Posted June 22, 2011 Well, I gotten the go ahead to fab the table. Suggestions? I was thinking a 4x9 or 4x6 cut to size. Then renforced with 1x2's. Link to comment
The_Ghan Posted June 22, 2011 Share Posted June 22, 2011 I did mine this way. Cheers The_Ghan Model_Train_Set_Base_PG.01.pdf Model_Train_Set_Base_PG.02.pdf tchff_2391.pdf Link to comment
NozomiFan Posted June 22, 2011 Author Share Posted June 22, 2011 Very nice! I think I'll just by a 4x6 table. Link to comment
Guest Closed Account 1 Posted June 23, 2011 Share Posted June 23, 2011 I built 2 36X72 inch tables out of 1X4 with beams across and ran 1X1 around the perimeter to support the 1 inch blue tongue and groove foam insulation. It's light weight and strong. I recommend using the Ntrak manual to plan your tables as they are modular. You can easily have a layout that will attached to other clubs as well as add your own corner tables to make a home layout from the same traveling table. Standard Ntrak depth is 24 inches no more than 36 deep and as long as you want to transport. Picture shows the frame, supports and foam sheets. Wood looked great until we ripped it. Then it did weird things. Notice the gap? Reinforced with a short beam and liquid nails. Link to comment
