Guest Closed Account 1 Posted October 30, 2011 Share Posted October 30, 2011 It's the decoder. It will not send enough juice to the headlight when in one position. Tested the board separately. Cleaned contacts. Headlight with decoder is dim. Link to comment
The_Ghan Posted October 30, 2011 Share Posted October 30, 2011 If you got it from HS they will probably replace it. Cheers The_Ghan Link to comment
Guest Closed Account 1 Posted December 12, 2011 Share Posted December 12, 2011 Bummer. Got the replacement FL12 decoders last week and just got a round to installing them. Ok the decoders are working properly and the directional lights function correctly. When I went back to double check determine which of the other decoders was the issue, the decoder smoked and took out the stock board. Kato USA will replace the FL12 with no problem but, they are checking into the light board. Link to comment
Martijn Meerts Posted December 12, 2011 Share Posted December 12, 2011 Shouldn't be a problem getting a replacement light board. The board might also be fixable, depending on the damage. Resistors and LEDs are easy enough to replace, easy to find, and cheap ;) Link to comment
The_Ghan Posted December 13, 2011 Share Posted December 13, 2011 Quote Shouldn't be a problem getting a replacement light board. The board might also be fixable, depending on the damage. Resistors and LEDs are easy enough to replace, easy to find, and cheap ;) Agreed Cheers The_Ghan Link to comment
Rintintin Posted April 7, 2012 Share Posted April 7, 2012 Hello all N-fans! I'm interested in buying this fantastic KATO train, but in HS it's in "waiting list mail" mode Do you know any expected date to have it available again? Thanks in advance for your help & Best Regards, Rintintin. Link to comment
Guest Closed Account 1 Posted April 7, 2012 Share Posted April 7, 2012 Send an email to Tu-Han at Popondetta.jp http://www.popondetta.jp/asp/cgi-bin/shop.php?uid=11210285.893233953&screen=gds_srh&reload=&word=10-857&srh2=%B8%A1%BA%F7&gds_view=&gds_inf=&display=&bid=&ctgry=&knd=&mkr_nm=&mdl_nm=&type_nm=&prc%5B0%5D=&prc%5B1%5D=&year=&etc1=&etc2=&etc3=&etc4=&etc5=&sort=0&soldout=1&srh=&clr=&set_rep=&page=1 Tell them you would like to buy the train and give them the stock numbers of everything you want to buy. They will respond and clearly say yes I agree. They're prices and shipping is a lot lower than HS. Link to comment
linkey Posted April 7, 2012 Share Posted April 7, 2012 There is no exact date but it would be mid-late June but that is the basic set with M1 track starter set. Most likely they will re-release them at the same time. Link to comment
Rintintin Posted April 7, 2012 Share Posted April 7, 2012 Thank you for your answers! I hope to have it before June... Cheers, Jose. Link to comment
The_Ghan Posted April 8, 2012 Share Posted April 8, 2012 Bigman also has the E5 set much cheaper than HS. I've been purchasing from Bigman for around 6 months now. Cheers The_Ghan Link to comment
Rintintin Posted April 8, 2012 Share Posted April 8, 2012 Thank you very much for your help Finally, I have ordered it to Popondetta. I will tell you when it arrives to Spain, this will be my first Shinkansen! And I feel that it won't be the last one! (I also wanted the "Nozomi" 500 series, and the 800 series, but finally I've decided to choose the "Hayabusa" one). Cheers Link to comment
Darklighter Posted April 8, 2012 Share Posted April 8, 2012 @Rintintin: Did you order the complete 10-car set? If so, how much is shipping? Link to comment
Rintintin Posted April 9, 2012 Share Posted April 9, 2012 Quote @Rintintin: Did you order the complete 10-car set? If so, how much is shipping? I still don't know the shipping cost I'm waiting an answer from Popondetta, because I've ask for other items and they will give me the total amount... I've made the register form (for foreign users) but I don't know how to place an order (I don't understand japanese ). I will keep you informed Cheers, Rintintin. Link to comment
Rintintin Posted April 11, 2012 Share Posted April 11, 2012 Quote @Rintintin: Did you order the complete 10-car set? If so, how much is shipping? Finally, the shipping cost were a bit expensive (about 7000 JPY) because I've purchased several things, and I live in Spain. Cheers, Rintintin. Link to comment
clem24 Posted April 11, 2012 Share Posted April 11, 2012 The good news is that they don't make a profit on shipping - whatever you paid is whatever usually appears as postage paid. On the other hand, they tend to use very thick and heavy boxes which make up a large part of the weight. I suppose it's good and bad but if something is probably packed (i.e. perfectly sized box and padded so that no empty space exists), then it'll be just as strong. But then again, can't blame them given their presumably huge mail order business. Still, Popondetta is now the *only* place that I shop at. Link to comment
Darklighter Posted April 11, 2012 Share Posted April 11, 2012 Quote Finally, the shipping cost were a bit expensive (about 7000 JPY) because I've purchased several things, and I live in Spain. Muchas gracias por la información! Link to comment
Rintintin Posted April 12, 2012 Share Posted April 12, 2012 Quote Quote Finally, the shipping cost were a bit expensive (about 7000 JPY) because I've purchased several things, and I live in Spain. Muchas gracias por la información! De nada (you're welcome) Link to comment
Rintintin Posted May 13, 2012 Share Posted May 13, 2012 Hi people Finally, I've got it! My new KATO E5 Shinkansen has arrived at home! (after one month in customs ) Now I'm enjoying with it, and installing the LED lights (new KATO 11-212 version 2). I will show you pictures later. Thanks all for your help & Cheers. Link to comment
Bernard Posted May 13, 2012 Share Posted May 13, 2012 Quote Hi people Finally, I've got it! My new KATO E5 Shinkansen has arrived at home! (after one month in customs ) Now I'm enjoying with it, and installing the LED lights (new KATO 11-212 version 2). I will show you pictures later. Thanks all for your help & Cheers. Enjoy It! One month in customs? I guess the agents like the E5 too. Link to comment
Rintintin Posted May 13, 2012 Share Posted May 13, 2012 Quote Quote Hi people Finally, I've got it! My new KATO E5 Shinkansen has arrived at home! (after one month in customs ) Now I'm enjoying with it, and installing the LED lights (new KATO 11-212 version 2). I will show you pictures later. Thanks all for your help & Cheers. Enjoy It! One month in customs? I guess the agents like the E5 too. Yes, I thought that too! This train is a jewell! I have already installed the LED lights and it's perfect! Now, I need to convert to DCC mode... that should be a problem, but I will think in it later I love it! Cheers. (UPDATE) Here are several videos from my YouTube channel. Enjoy it! Link to comment
