Guest Closed Account 1 Posted November 6, 2011 Share Posted November 6, 2011 Faller 272582 Tunnel Portal 25x170x100mm Does this look like it can be stretched out to 4.5 inches? Modern tunnel standard is 1 9/32"/32mm or 17 feet (1:1). A little hot water can really help make big changes to plastic. Hold form, soak for a minute or two then drop into ice water for a few more minutes. http://www.faller.de/xs_db/DOKUMENT_DB/www/anleitungen/272582_anl_01.pdf Link to comment
inobu Posted November 10, 2011 Author Share Posted November 10, 2011 ok, So I'm back at it............. What I did was take the WS portal 1156 and impose the ICE portal behind it to get a clearance and size reference. I know that some have complained about the size of the WS portal. I extended it 4.75 mm on each side and 2 mm on the height. The Double Unitrack fits exactly in the WS Portal where as the code 80 track can be adjusted based on looks. The 4.75 mm can give you a 30 inch walkway on each side it you want. [smg id=1401] I'm going to add a lip on the back inner wall so a styrene sheet can be placed inside of the tunnel adding wall depth. I think with that you could add tunnel lights along the wall. [smg id=1402] I simplified it. If something look off or is missing let me know. Inobu 1 Link to comment
inobu Posted November 11, 2011 Author Share Posted November 11, 2011 Webskipper, I don't think the stretching is going to work. Its too long and not enough material. I stretch this portal and the distortion level is high. I'm not sure that you can control (evenly expand the plastic) without tearing or shredding it. [smg id=1403] This is a 124mm span from inner wall to inner wall. Link to comment
Guest Closed Account 1 Posted November 11, 2011 Share Posted November 11, 2011 You're right. Looks like clearance issues. Sweet program. I'll take two commercial ones and kit bash them to make it work. Link to comment
inobu Posted November 11, 2011 Author Share Posted November 11, 2011 I know its different from what you have but I'm trying to give you a few looks. This is a center cut which may be the easiest method. You may be able to disguise the front with a sign. [smg id=1404] Inobu Link to comment
Guest Closed Account 1 Posted November 11, 2011 Share Posted November 11, 2011 Quote You may be able to disguise the front with a sign. [smg id=1404] Inobu Exactly my thought. A sign, signal lamps, or just some overgrown vegetation. Oblonged with flat ceiling, it still looks very cool. The second one with rounded ceilings bound to be tall and its going to be loud with all that air compressed by 3 passing bullets. :) The intended tunnel length will be about 4-5 inches. Just enough to separate my layout from the other Ntrak scenes. Link to comment
inobu Posted November 15, 2011 Author Share Posted November 15, 2011 OK, I'm going for it. [smg id=1416] Its going to be a three piece portal. The pieces are represented by the 3 color's with the crown, left and right side. If I can I'm going to try to get it to two pieces crown and wall. We will see. Urethane plastic likely, concrete gray or close. Hopefully I can get the first article done in a day or so. Inobu 2 Link to comment
Guest Closed Account 1 Posted November 15, 2011 Share Posted November 15, 2011 You're teasing us with the sexy black carbon fiber. Link to comment
inobu Posted November 15, 2011 Author Share Posted November 15, 2011 lol, Gonna get it done....while I have the time. Inobu Link to comment
Guest Closed Account 1 Posted November 16, 2011 Share Posted November 16, 2011 I bought 2 Faller Ice tunnel portals to see how 2 will work with 4 tracks. Will post the results. Link to comment
linkey Posted November 17, 2011 Share Posted November 17, 2011 Quote You're teasing us with the sexy black carbon fiber. Now, now Webskipper, don't give Inobu any ideas lol Link to comment
inobu Posted November 23, 2011 Author Share Posted November 23, 2011 Should have something to show by next week. Unexpected issue and holidays slowed me down. Inobu Link to comment
Guest Closed Account 1 Posted December 4, 2011 Share Posted December 4, 2011 My Noch 34840 ICE Tunnel portals arrived. Little disappointed. Its hand painted foam. Expected a better paint job. It does have a good starting point for a hillside or mountain. Still waiting on the Faller, which looks like the winner. It comes with a short length of tunnel which forms a perfect angle for the portal. No guessing. Link to comment
inobu Posted December 4, 2011 Author Share Posted December 4, 2011 Foam ? What kind? Inobu Link to comment
Guest Closed Account 1 Posted December 4, 2011 Share Posted December 4, 2011 Hard foam. 80mm wide for two tracks. Link to comment
inobu Posted January 15, 2012 Author Share Posted January 15, 2012 (edited) I had a couple of design issues again that I had to work out. So I basically had to start over.Everything looks good now and I added the feature that allows you to slip a sheet of styrene into the face to extend the tunnel depth. It has the front and rear piece that holds the styrene in a arc. You can glue or just tape the outside in case you want to change the depth.Here is the final rendering of it. This portals is about a 8" or 210mm in depth from tip to rear. The styrene center is about 4" or 97mm. Without the center extension the portal is about 4.5" or 116mmThe slot is for a .03" or .77mm sheet of styrene. You can see where it slides into the front. The rear piece has both a slot and lip (you can see it in the lower left of the image) so it can be flipped around if you don't need the depth. It fits into the rear of the front piece. There is a bit of a seam but if you paint the wall a flat gradient to black you should not see it.What is good about this is you can really expand on it. Add lights to the styrene, glue wall images to the interior. Because its sturdy you can really work with it. InobuThis is it, what ever happens happens, I got to move on to my next project. lol Edited July 28, 2014 by inobu 2 Link to comment
Guest Closed Account 1 Posted January 15, 2012 Share Posted January 15, 2012 The Faller ICE portals I ordered 2 months ago will be here Tuesday. Interested in seeing how to widen them. Awesome job Inobu! Link to comment
inobu Posted January 15, 2012 Author Share Posted January 15, 2012 Thanks, Now I see why it takes so long for stuff to come out. Lot of rework. Inobu Link to comment
Guest Closed Account 1 Posted January 18, 2012 Share Posted January 18, 2012 Faller ICE Portal 272582 and Noch ICE Portal 34840 Pics. The Faller gives the modeler a choice of portal widths, a clear plastic tunnel shell, concrete decal, and sign decals. The Noch is a foam version that is ready to a part of the landscape. Inobu out did himself on the scratch built version. Link to comment
disturbman Posted January 18, 2012 Share Posted January 18, 2012 Inobu, that's an incredible job! This portal is really beautiful. Link to comment
cteno4 Posted January 18, 2012 Share Posted January 18, 2012 whoops i missed this! I agree, superb job Inobu! so is it going into production?! brilliant with the styrene insert! what is the width at the base of the mouth there? im starting to think if this might work on the jrm mountain portals! jeff Link to comment
inobu Posted January 18, 2012 Author Share Posted January 18, 2012 Thanks guys..........This thing is killing my. I still have to go back and make some modifications to avoid a few undercuts so another revision is in the works....so much for "this is it"..... Jeff here are the dimensions. The portal inside heights is 2.13" (54mm). The width 2.72" (69mm) inner floor edges at the mouth. The total heights is 2.82" (71.75 mm) The main portal depth is 2.68" (68mm) The rear extension is 1.57" (40 mm) With a styrene insert you should be able to extend it another6" (150mm) I kept it close to the WS portal [smg id=1401] I'm telling you.............because of the styrene sheet you can add lights so easy. Inobu Link to comment
inobu Posted February 10, 2012 Author Share Posted February 10, 2012 Part 1 Done.... After..what? a year.... I got the first part done. 2 more to go. I should have it done in a day or so. Finally. I think these will be really good pieces....at least I hope. [smg id=1433] Inobu Link to comment
cteno4 Posted February 10, 2012 Share Posted February 10, 2012 Inobu, very cool. i have to set up that end of the layout next week to measure stuff for our new skirting so ill see if this can fit into our mountain entrances. you going to start producing some of these for sale now?! jeff Link to comment
