CaptOblivious Posted April 7, 2011 Share Posted April 7, 2011 Sounds like a couple of hall sensors attached to that microcontroller. Would be interesting to see how the bus reacts if put on its back while running, and you waved magnets over different bits on the underside… Link to comment
cteno4 Posted April 8, 2011 Share Posted April 8, 2011 Sounds like a couple of hall sensors attached to that microcontroller. Would be interesting to see how the bus reacts if put on its back while running, and you waved magnets over different bits on the underside… all i can think of is "hocus pocus" jeff 1 Link to comment
CaptOblivious Posted April 8, 2011 Share Posted April 8, 2011 Sounds like a couple of hall sensors attached to that microcontroller. Would be interesting to see how the bus reacts if put on its back while running, and you waved magnets over different bits on the underside… all i can think of is "hocus pocus" jeff That's why Hall-effect sensors are so much fun!! Link to comment
cteno4 Posted April 8, 2011 Share Posted April 8, 2011 yes i was thinking hall effect sensors as i didnt think they could do them w/o something registering the interval the field was applied and the polarity of the field. perhaps a strong rare earth magnet on the end of a wand could make the bus start/stop and change speeds! they have it so you can lock the wheels to run w/o track! cheers jeff Link to comment
rankodd Posted April 9, 2011 Share Posted April 9, 2011 Just got my sets today and was playing a little. The magnetic controls are polarized and directional. Haven't found how to do a timed stop, but applying a magnetic field of one polarity to the right hand side of the bus makes it stay stopped. Applying that same polarity field to the left side of the bus triggers the speed. I'll attempt to post a video demonstrating. Now, that was an extremely powerful magnet. I'm not set up for much playing with making road tracks, intersections, etc. It does look like a fully controllable road network is possible, though. 1 Link to comment
rankodd Posted April 9, 2011 Share Posted April 9, 2011 First round has the switch set to Go, second to Stop. I don't have the speed magnets installed under the roadbed. Link to comment
cteno4 Posted April 9, 2011 Share Posted April 9, 2011 rankodd thanks mucho! did you have the stop magnet installed? i think with that then the bus stays stopped until the switch is moved to go. jeff Link to comment
rankodd Posted April 9, 2011 Share Posted April 9, 2011 rankodd thanks mucho! did you have the stop magnet installed? i think with that then the bus stays stopped until the switch is moved to go. jeff It's actually the other way around. No magnet means it stops permanently. With the extra magnet the stop is timed. One more video. I decided to try the over/under layout posted above. The bus does not like the gradient, much. Link to comment
KenS Posted April 11, 2011 Share Posted April 11, 2011 Here's my promised video, showing how the under-road magnets affect operation (not my best video, really, but I think it gets the info across). 3 Link to comment
brill27mcb Posted April 12, 2011 Share Posted April 12, 2011 Great video, and very informative. How many laps (or how much time) do you think you will get to a battery set? Rich K. Link to comment
KenS Posted April 12, 2011 Share Posted April 12, 2011 No clue. It will likely depend in part on whether you use true LR44 cells or the longer-lived (and much more expensive) SR44. I've run a few dozen circuits of the track (I think) withough exhausting the first set. I may try an endurance test one of these days, as I'm curious about that myself. Link to comment
rankodd Posted April 12, 2011 Share Posted April 12, 2011 I got, very roughly, a couple of hours straight out of my cheap DX bulk batteries. Not sure if I truly drained them or not - the "spent" batter still has ~1.35v in it, down from about 1.6v fresh (on my meter, anyway.) Not sure if I can get any more runtime by letting it rest. Link to comment
john_ibw Posted April 16, 2011 Share Posted April 16, 2011 I have finally given in and ordered the sets. Has anyone tried putting one of the Tomytec bus on the Faller guide-wire and vice versa? Faller offers distance control and traffic signal control systems as part of their offerings under the car system. Though pricey (in my opinion), the control systems along with required sensors may be able to guide / control the Tomytec buses alongside Faller ones. I read somewhere (though I am not sure that the information was accurate or just a rumour!) that Tomytec borrowed from Faller the technology for the run system. Link to comment
cteno4 Posted April 16, 2011 Share Posted April 16, 2011 John, actually i think it was tomytec licensed the technology from faller. But it looks like Tomytec has redone how the sensors work and added some circuitry w/in the buss. the faller system has no internal control circuitry on the N scale busses, save the on/off switch and a simple reed switch which can be activated by an electromagnet below the road to turn the bus off while the electromagnet is on. turn off the electromagnet and the bus proceeds. the tomytec seems to have two magnetic sensors that in various combinations will change the speed of the bus (fast<>slow) and will either pause the bus for 10 seconds or make the bus stay until the magnetic field is removed. so while it looks like tomytec is building in something to eventually give signal/crossing control over the busses its not clear if the control system work in exactly the same ways to be interoperable for control. the faller might work on the tomytec bus stop as you can slide the magnet in and out so it might work on the faller reed switch, but dont have a tomytec bus system yet to try it (i do have a faller). im guessing the steering mechanism is pretty much the same and they should track on each other's guide wires. follow the thread below and you can get some more of the details of some of the experiments users have tried with the tomytec bus control, its going to be interesting figuring out exactly how it all works. cheers jeff Link to comment
bill937ca Posted April 21, 2011 Share Posted April 21, 2011 HS is taking reservations again for the The Moving Bus System Basic Set. http://www.1999.co.jp/eng/10130252 Link to comment
john_ibw Posted April 21, 2011 Share Posted April 21, 2011 Insert QuoteHS is taking reservations again for the The Moving Bus System Basic Set. http://www.1999.co.jp/eng/10130252 and the prices has been reduced I think Link to comment
keiman Posted April 21, 2011 Share Posted April 21, 2011 Have any of you guys who already have this tested it on various gradients? Curious because thinking up bridge over the track and back down to same level. Link to comment
bill937ca Posted April 21, 2011 Share Posted April 21, 2011 and the prices has been reduced I think Is 15% off. Link to comment
bill937ca Posted April 21, 2011 Share Posted April 21, 2011 Have any of you guys who already have this tested it on various gradients? Curious because thinking up bridge over the track and back down to same level. There is a video on this down below and I've posted a photo below also. Why not read the posts before asking a question? Link to comment
lordwinslow2 Posted April 21, 2011 Share Posted April 21, 2011 Just got an email from Hobby Search, they are taking reservations for a new batch of Tomytec Moving Bus System. Thinking about reserving 2 of them. Winslow Link to comment
keitaro Posted April 21, 2011 Share Posted April 21, 2011 We know lord Bill while the video does show it going over a bridge. Perhaps kei was wanting more informative answer such as it has a max grade of x% Reasons this is so is because of z and because of y.... Link to comment
lordwinslow2 Posted April 21, 2011 Share Posted April 21, 2011 Just got an email from Hobby Search, they are taking reservations for a new batch of Tomytec Moving Bus System. Thinking about reserving 2 of them. Winslow Um make that I have put 2 on Reserve from Hobby Search...now i got to put in some OT. Winslow Link to comment
keiman Posted April 21, 2011 Share Posted April 21, 2011 We know lord Bill while the video does show it going over a bridge. Perhaps kei was wanting more informative answer such as it has a max grade of x% Reasons this is so is because of z and because of y.... Max gradient was what i was interested in. Looking at hand built track. Have a nice roll of steel wire that someone liberated for me. Saw the video. Link to comment
rankodd Posted April 21, 2011 Share Posted April 21, 2011 Price is 15% off now - when I ordered mine it was 20% and I paid 6240 each. The buses don't like gradients at all - likely because they're very light. I did the over/under video on this thread, and it slipped the whole way up. If you're planning something like that, make sure you have a long run up... Link to comment
keiman Posted April 21, 2011 Share Posted April 21, 2011 Not sure wether to go for it . was hoping they might climb a reasonable gradient, but if the traction is poor think static buses may be an easier option. Link to comment
