cteno4 Posted August 8, 2022 Share Posted August 8, 2022 Tony, great work! These tiny bits are the hardest of the sankei to build. You jumped into the deep end here. Larger structures are easier as parts are not so tiny and the tabs and rabit joints are easier to fit. Tiny structures lie this little shrine can’t get some of the helpful assembly designs in that small and a small mistake on alignment is big in relationship to the size of the overall piece so way more noticeable if you goof on a joint. kudos! cheers, jeff 1 Link to comment
maihama eki Posted January 12, 2023 Share Posted January 12, 2023 A simple little kit. Sankei MP04-59 "Lottery Booth" I painted the roofs, added some additional signs, a "glass" window, and some interior bits including the attendant and a light. 15 Link to comment
bc6 Posted July 14, 2023 Share Posted July 14, 2023 Oh wow thats pretty cool maihama thanks for sharing it. Link to comment
bc6 Posted July 14, 2023 Share Posted July 14, 2023 (edited) This is a Sankei that Ive almost completed next too an Outland Models building Ive completed. Edited July 14, 2023 by bc6 7 Link to comment
cteno4 Posted July 14, 2023 Share Posted July 14, 2023 How did you like assembling the sankei kit? jeff Link to comment
bc6 Posted July 14, 2023 Share Posted July 14, 2023 It was an interesting assembly and my first Sankei kit. I got it because no other company offered a similar building or it was out of stock. I thought the plans were amazing blueprint quality just about. I wish I was a bit more prepared to assemble the kit with the correct tools like a really sharp xacto blade, micro glue dispenser and tweezers . I may venture to do another kit if there is something that catches my eye, Overall I think it was worth the effort that I put into building this kit and will be a prized addition to my layout. Link to comment
cteno4 Posted July 14, 2023 Share Posted July 14, 2023 Good to hear you enjoyed it. first one is the hardest to get into their process and design and then they get easier. Kind of like making oancakes, first one is usually a bit of messing with and may come out a little wonky but the rest of the batch is easy. Yes they do require really sharp xacto knife tips as the sankei laserboard has a lot of hard resins in it and very hard, dense fibers that makes it hard to cut thru the little tabs. But the laserboard does not singe with cutting and is pretty robust to moisture. Might try the xacto Z series blades that have a zirconium nitride coating on the edge. They do seem to stay on the ultra sharp side longer than standard blades do. Stropping the blade edge now and then on a very fine nail file sponge also can help keep the tip cutting well on the harder stuff. yes smaller glue applicator helps over using some sort of applicator to transfer little glue blobs and lines. I find the Arleen’s tacky glue is just right for sankei and paper crafting as it’s thick and does not run or overly soak papers with extra moisture and it sets pretty quickly to a good hold before full curing. You can get it in nice little pen applicators that work well for little dots and lines of glue. You can refill these from cheaper big bottle later. tons of nice fine tweezers cheap on ebay if you root around. Go for stainless not the black painted ones. You can pick up pretty fine tips for under $3 and an array of tip types. Probably one of the most handiest tool to have a variety of. cheers, jeff 1 Link to comment
N-Osoi Posted September 21, 2024 Share Posted September 21, 2024 Just made my first Sankei kit, the MP04-21 public toilet 😀. So small! Definitely needed two sets of tweezers, reverse tweezers, and a magnifying lamp. Have only pained the walls with a dirty white colour as I preferred the white colour on the item picture to the pine-y colour of the paper/card. Looking forward to making more! 13 Link to comment
Pashina12 Posted December 9, 2024 Share Posted December 9, 2024 Having had a sudden urge to do something concrete, I decided to build the little bus stop waiting shed (MP04-25 バス停A). I'm looking at that little circle of paper that's supposed to go on the signpost and wondering how in the world I'm supposed to cut that out neatly... I do have a hole punch but it's like twice the diameter of the sign... super tempted to just ignore that and use one of the bus stop signs from the GM set of street signs (35-3)... Link to comment
cteno4 Posted December 9, 2024 Share Posted December 9, 2024 I’ve a couple of different little leather punch sets I’ve use to both cut holes in things as well as punch out small circles like this. You need to punch paper on something more stiff, I’ve used the dense photoboard and even the waste of sankei laserboard to cleanly punch out small circles. jeff Link to comment
Pashina12 Posted December 9, 2024 Share Posted December 9, 2024 Wow for C$7 that's quite the deal even if it is of "expected quality". I'll be ordering one I think, once the posties are back to work. Link to comment
cteno4 Posted December 9, 2024 Share Posted December 9, 2024 Yeah not the best quality but fine for punching some paper, cardboard and felt. I’ve also got some small hole punches like 1.5-3mm. jeff Link to comment
bc6 Posted January 31 Share Posted January 31 This is my latest Sankei kit, I saw a building like it on YouTube with the Yokohama logo and decided to add one of my own. It was either that or a train shop lol. 5 Link to comment
cteno4 Posted January 31 Share Posted January 31 Decided against Hamaya or Ohdan? jeff 1 Link to comment
bc6 Posted February 1 Share Posted February 1 (edited) it,was actually going to be called the train shop lol 😆 Edited February 1 by bc6 Link to comment
