Bigdog Posted October 25, 2023 Share Posted October 25, 2023 This happens every few seconds. Not sure if it is motor pickup or what? Any ideas could help Link to comment
cteno4 Posted October 26, 2023 Share Posted October 26, 2023 does it happen in the same places on your track? Have you tried just wiping a cloth on your track to see if lots of gunk on the track? If dark likes appear easily I would first try cleaning your track well. https://jnsforum.com/community/topic/18298-how-to-clean-black-residue-on-tracks-and-train-wheels/#comment-225743 if it’s primarily happening on curves then it could be a pickup out of adjustment that misses contact when the truck turns. Have you tried flipping it over and tried applying power directly to the wheels with some stripped wires or probes hooked to your power supply? If it will stutters with power directly to wheels it may be pickup crud, but also pop the chassis out and try applying power directly to the power strips if they are visible. If still stuttering it’s the motor. can you see if any crud on the wheels? jeff Link to comment
Bigdog Posted October 26, 2023 Author Share Posted October 26, 2023 I’ve tried cleaning both the track and the motor but it still stops and I have to give it a little tap of encouragement for it to start moving again. I’ll try applying power later. Thanks for the advice Link to comment
Kamome Posted October 26, 2023 Share Posted October 26, 2023 Could be a contact issue. The E6 is compatible with the EM13 decoders so have a strange shape on the brass pickup strips in the motor car. May be worth checking they’re seated correctly, the wheel contacts are making correct contact with the strips, and the strips to the motor. Probably something annoyingly simple but as these things rely on brass contact strips instead of soldered wiring, they can be temperamental. Link to comment
