Using the Tomix N-DU204-CL 5518 on Kato track
BulletTrain816
BulletTrain816
I want to buy the Kato V13 and I was wondering if I could use the Tomix controller due to its double control capabilities. Is this possible and will I need an adapter if so which one?
Edited by BulletTrain816
If you are terrified of soldering you can use these solder sleeves and just heat the sleeve with a match or lighter to melt the solder and shrink the sleeve down to insulate the butt joint in the wires.
Or you can use a quick connect terminal (like D 2 in 6 out) to easily add feeders as needed with no soldering. You can even double up feeders into output terminals.
