Non-Power Routing for Tomix Turnout
lctrains428
lctrains428
Hello,
I have a Tomix Turnout N-PY280-15 (#1240) that I want to turn the power routing switch off.  I need advice on how to do this.  There is a switch that I have to turn off but I have no idea how to access it.  Thanks in advance for any help or suggestions.
I don't think there is a switch to access. The tomix turnouts are not designed like the Kato Unitrack 481mm radius turnouts. The simplest thing to do to nullify the power-routing is to have track feeders on all 3 legs of track attached to the turnout.
Rich K.
Confirmed. All the Tomix turnouts* that I use are power routing and there is no switch to change that.
*Except the 1245 Double Slip Turnout N-PXR140-15(F) and 1246 Double Slip Turnout N-PXL140-15(F).
lctrains428
Rich K.
Thanks for your advice.
lctrains428
Thanks for confirming this.
To remove the power feeding feature of Tomix PY-280-15, you can remove the little sliders that actually do the power routing. Remove the cover at the bottom of the turnout (unscrew 3 little screws), then carefully remove the sliders (two elongated metal pieces) in the middle. Then, screw the cover back and you're done 👍 Don't lose the sliders if you ever want the turnout to be power routing again!
image.thumb.png.a45949c105dd4653cb91f74c46687a03.png➡️image.thumb.png.9b2ab56e9ec1496b448a5663c3b80fee.png
Edited by katem
So I just tried this with one of my Tomix turnouts, and now the loco stops as soon as it's through the point, in either direction - seems it's not feeding power at all past the frog like this?
There are two spots on my trackplan where I need power to always feed through, so that it still gets power when the routing is changed; this one lefthand turnout, and at a double-slip.
How could it, when you removed the power-conducting element 🙂 Making the power pass through to both branches would require the opposite - adding something. The space is pretty tight for a simple modification though. Before modifying the turnout, I would suggest to use power feeders inside all branches that should be powered together, like Rich suggested few posts above. Power feeders and Y-cables are the basic way to go.
Edited by KateM
Another way would be to modify the turnouts as shown in this discussion (see the final photo in Anvalo's Dec. 15 post):
This has the opposite effect from removing the conducting sliders, by bridging everything together instead, but it's a pretty permanent modification. It has the same effect as adding redundant track feeders on all approaches to the turnout.
Rich K.
Edited by brill27mcb
