KenS Posted April 7, 2010 Share Posted April 7, 2010 That looks very nice. it definitely needs more cars to look like Japan. Link to comment
Bernard Posted April 7, 2010 Share Posted April 7, 2010 IST - The layout looks great.... but don't you know layouts are never finished, we always find something to add on or redo. Link to comment
clem24 Posted April 7, 2010 Share Posted April 7, 2010 One of the recent copies of RM Models showed some home made straight sections of unitram track (basically just unitrack, a base to match it to the height of the roadplates, and then plastic overtop for the road) and some neat layouts. I can post some scans if that's allowed here... Link to comment
ToniBabelony Posted April 7, 2010 Share Posted April 7, 2010 Looks really great, but the grey low building in the middle makes my heart bleed. I don't think in Japan a pre-war corner building would be blocked off by an ordinary combini (small supermarket) like that. I really deserves to be on a street corner with teh combini in a less prominent place... Link to comment
westfalen Posted April 8, 2010 Share Posted April 8, 2010 That looks very nice. it definitely needs more cars to look like Japan. Maybe they are leaving their cars at home and catching the new light rail into town. What it needs to look like Japan, a big city at least, is people, lots of people. And when you get them on add a few more for good measure. Link to comment
IST Posted April 8, 2010 Author Share Posted April 8, 2010 Thanks for your comments. I have two other projects also (you can see a big size (really!) picture one of them here, which will be my first modul ever if I will have time to finish it), so it is very hard to find a good compromise between them. But peoples and cars are on my list and I would like to buy also a Tomix office building, or two and make a small skyscraper. And sometimes I am dreaming about Shinkansens, but my wife would not prefer to collect another type models... Link to comment
Hobby Dreamer Posted April 10, 2010 Share Posted April 10, 2010 I can post some scans if that's allowed here... Please do! Link to comment
wmo168 Posted April 28, 2010 Share Posted April 28, 2010 You should be able to stack the Kato structure with several unit to make skyscraper. Search the forums and there are people who had done it. Link to comment
IST Posted May 30, 2010 Author Share Posted May 30, 2010 Just a short update: In this weekend I rebuilt my Unitram layout. I frankly bored the base oval layout, so started to thinking about a little extension with one part of my current Unitrack pieces. I wanted to make a connection between the two separated tracks with the double crossover from the V7 set and also wanted to make a short siding for one tram. The available space was about 140*60 cm. You can see the final version on the pictures. My biggest problem was that the spacing between the two tracks at the Unitram set is 25 mm at the end of a curve, while the crossover has 33 mm spacing. I tried some variation with my different radii curves, but I had no luck or the space was small. After some useless test of track connection, I simply connect the Unitram track and the crossover with 248 mm long track. It looks not so good, but works perfectly, trams can go on it without any problem. After the changes I quite liked to play on the layout, changing between the two rails with my trams, go to the siding and back, so it was fun. Now I am thinking about buying plus office buildings to hide the Unitrack section of the back area of the layout. (Yes, I saw the new Kato buildings...) 1 Link to comment
Hobby Dreamer Posted May 30, 2010 Share Posted May 30, 2010 Nice Job! You did the best one can do within the limits of what track is available. The intersection in the lower left looks great. Although Kato Unitram track looks terrific, its just crying out for more variation and I hope Kato will respond. That's a nice table you have with room for your controls etc underneath. Thanks for sharing! Rick Link to comment
IST Posted June 1, 2010 Author Share Posted June 1, 2010 It is a common Ikea Bonde TV bench. Really good and useful it can hide all of my model train boxes. :-) Currently I am thinking about hiding the gap between the 2 Unitrack tracks. I think I will make a photo about the Unitram baseboards to use it as a texture, print it and glue it to something cutted to the right size. Link to comment
cteno4 Posted June 2, 2010 Share Posted June 2, 2010 IST, hey looks great! you might try just plopping the track on the scanner to get your texture. this is basically how im building my tram ttrak module roads. 0.25" x 0.040" styrene strip is perfect to fit between the spikes on unitrack and with a paper top come up just below the rail tops. this is what im using on my street car ttrak modules. i was going to then put my street sections up against the outside rail, but now im thinking of only going out to the edge of the roadbed with the paving blocks then butting my streets up against that. this way its easier to tear up the streets later if i decide to change markings, etc and it matches well with the unitram if that ever gets intermingled with the ttrak modules. only problem with this is you have to very firmly glue down your paper to the styrene between the rails as if any little corners start to come up they will be nasty catchers for the trucks to catch. my solution is to take my printout of my center road texture and put it on the light table and mark where i want the strip to be on the back side of the larger paper. i print the texture strip wider than the actual final strip. then liberally glue the strip down onto the back of the paper, weighted down well to give a very even bond. then i just trim the paper from the strip (along with any excess glue). then give it a shot of matte spray to seal the edges up well and protect the surface. this also lets you play with chalks on the road surface for stains and wear and still take it off if you are not happy with it or go too far (if you do that on the printed paper directly it sticks for good). you have created a great poor mans unitram straight track! im betting a lot of folks will start doing this to expand unitram affordably. the road plates give you a host of road signage details to play with as well! great work! cheers jeff Link to comment
westfalen Posted June 3, 2010 Share Posted June 3, 2010 How hard would it be for Kato to run off some straight Unitram track sections and package them separately, maybe 4 to a pack? They are going to have to start doing something to keep consumers interested in the product. Link to comment
Hobby Dreamer Posted June 3, 2010 Share Posted June 3, 2010 Great job IST !! How hard would it be for Kato to run off some straight Unitram track sections Straight track is a no-brainer but I wonder if they are holding back so people buy their "system" of track. If they just sold the track maybe no one would buy the oval set. (And then they would not get their structures etc.). But anyone who has the oval will want more track! I also sense that if they sold track separately now, before a "buy-in" to their track system, people would just get Tomix track. I also wonder if they are acting in a manner to not compete with themselves. Thanks Jeff, for those pointers! Cheers Rick Link to comment
IST Posted June 3, 2010 Author Share Posted June 3, 2010 - Scanner... What a clever idea, it would made easier my yesterday evening. Thanks, good tip, I will try it in the weekend. - Styrene: I have never used this before, which is not a big deal as I do not have any modeller experience, but I will looking for it. I used cardboard, but it was too thin. - Wider strip: good point again. I was thinking how can I solve that the paper does not come up at the end and this is the solution. Link to comment
cteno4 Posted June 3, 2010 Share Posted June 3, 2010 IST you can get the strip styrene in the hobby shop, then just chop it to your desired length. on the outsides of the tracks im finding that .020 thick styrene works best once the paper is on top. this can then go out on top of the spike heads on the outside of the rail, butt up against the rail. this gives you a slight elevation on the rail which is good to keep good contact with the tram wheels and rail (any bump up might jump the wheels up a tad). nice thing about the styrene is that it stays pretty flat and wont warp with moisture, glue, etc. you can also probably find strip 020 styrene wide enough for your various track and road parts at your hobby shop as well or buy a sheet of it and cut it up. the 020 is pretty thin stuff and cuts like chipboard, just be careful as the knife tip will want to wander easily off the straight edge with styrene much more than with chipboard. i wonder in hungary they probably use metric measurements for the styrene though! .020 is approx 0.5mm. 0.25" is 6.35mm, so probably in 5mm or 6mm package. usually the strips are like 30-35cm long and like 6-10 to a pack here in the states. i toyed for a short time doing a decal to put onto the styrene for around the tracks, but quickly realized that trying to get long skinny decals onto thin strips like this would probably be very frustrating and not come out all that straight (a problem with the concrete pad pattern around the tracks!) paper is easier and cheap and lets you experiment a lot. for the final streets im using a heavy rag drawing paper that has a nice rough surface to give a tad of texture to the road surface. regular bond paper for the cement brick around the tracks as that feel smoother looking. have fun! keep posting picts of your progress! cheers jeff Link to comment
IST Posted June 4, 2010 Author Share Posted June 4, 2010 Thanks for the info, I will go to a hobby store today and have a look around. And yes, we use metric system. Link to comment
IST Posted June 7, 2010 Author Share Posted June 7, 2010 I had no luck on the weekend: - I couldn't buy styrene sheets in our DIY store, so I have to find another shop. - I scanned the basement and printed it, but the colours are different, so it didn't look better than my previous attempt with the camera. So, next turn, I will ask some help from my modeller friends. :-) Link to comment
cteno4 Posted June 7, 2010 Share Posted June 7, 2010 IST, try a plastics shop. they usually sell just plastic to folks like sign makers and such. usually in the industrial areas of town! you can buy larger pieces at a fraction the cost you get at the diy or hobby store. the also usually have a scrap pile (these places also sometimes do some custom fabrication or cutting for clients so will have a lot of odd scraps or at least a scrap bin) and sell it cheap or free. you want like 1mm and 2mm thick (i use 2mm between the tracks and 1mm outside. hobby shops usually carry a lot of pre cut strips of styrene at various thicknesses and widths for folks that do scratch building. this works great for the between the tracks as cutting long, very straight and parallel strips here is not easy to do. on the colors, you will probably need to fiddle with the hue, saturation, brightness, contrast and color balance of your scan to get it to print at the same color as the original plates. this is due to the printer not being perfectly color matched, always a challenge, but with a little playing in an image program (lots of free ones out there), and some experimentation (just do a small patch as a test to not waste a huge amount of ink) you should get it pretty close. if you have a friend who is a good graphics person they can probably help show you the tricks to get something to come out the desired color range on your printer. at least the scan will get things in perfect parallax so it wont be warped at all (hard to take a picture totally flat). best of luck! cheers jeff Link to comment
IST Posted June 29, 2010 Author Share Posted June 29, 2010 July issue of the British Model Rail magazine has just arrived. There are two pictures about my Unitram layout on page nr 91. I did not forget to mention the JNS Forum in the article of course. Link to comment
KenS Posted June 29, 2010 Share Posted June 29, 2010 That's great. It takes several weeks for MR to show up in the local bookstore here in the States, but I usually pick it up when it does. I'll keep an eye out for your layout. Link to comment
Bernard Posted June 29, 2010 Share Posted June 29, 2010 July issue of the British Model Rail magazine has just arrived. There are two pictures about my Unitram layout on page nr 91. I did not forget to mention the JNS Forum in the article of course. IST - Congratulations on the article and thank you for mentioning the JNS forum! Link to comment
Hobby Dreamer Posted June 30, 2010 Share Posted June 30, 2010 Looking forward to reading this! How did you get connected to the BMR magazine? I'm sure readers that are unaware of Kato's tram venture will find this fascinating. You've done a great job of experimenting with the new Kato product so the readers are lucky to see the best work out there. Rick Link to comment
