drt7uk Posted August 31, 2022 Share Posted August 31, 2022 Hi folks, seeking some advice. I'm after a replacement motor for my Kato E4 series. It's been repaired externally once but it's still a bit tempermental (randomly stops, has trouble starting without a nudge). The part is Assy E459-200. I've just emailed RG-Rokko and ModelTrainPlus, and it's sold out on HobbySearch. Any other thoughts or advice welcome...! Link to comment
disturbman Posted August 31, 2022 Share Posted August 31, 2022 (edited) If MTG and RGR cannot help, I would recommend to look on Yahoo Japan Auction via a proxy (ZenMarket or Buyee). There is often sold out parts floating around there. You could also place the order via MTG or RGR, as they both offer a "personal shopper" service. Edited August 31, 2022 by disturbman Link to comment
Wolf Posted August 31, 2022 Share Posted August 31, 2022 On 8/31/2022 at 10:26 AM, drt7uk said: Assy E459-200 Expand Thats just half of it. The actual item Number would be Kato 4621B "E459-200 power unit" with "4621B" being the actual Kato item number. I would search by that. I as well would recommend asking RGR or MTG to get the part for you, and put a saved search on buyee or ZenMarket. 1 Link to comment
Kamome Posted September 1, 2022 Share Posted September 1, 2022 It’s certainly a very unique assembly, no other train uses the same mechanism to my knowledge. I actually have a spare as I replaced my original first purchase’s motor as it was very noisy. I’m missing the motor cradle which was broken causing a lot of the issue, but not sure how well the motor still runs. I don’t recall that being the issue but as I was new to n scale on my next Japan visit I found a chassis in the old Kato Osaka store (no longer there) Some of the copper and plastic parts are in slightly bad shape as I used it for soldering practise once I had the new chassis, but I think the motor is sound. (I shall confirm when i get a chance) Looking at the motor, if you wanted a new one, I wonder whether other loco motors would fit. The sort of thing used in smaller locos. I think the thin plastic gear could be removed easily but not sure how simple removing a flywheel would be as similar motors seem to use dual flywheels. If it’s just the motor you need, if it works, I can send you this one if you’re happy to pay just the postage from Japan to wherever you are. 2 Link to comment
