Block power surges
Tyraforce
I'm looking for a solution for DC Kato Unitrack to get rid of surges (or whatever you call it) when changing blocks powered by different voltage.
The metal wheels of cars + lighting prep connects the two section long after the loco passed the insulator and the motor doesn't run well.
I know this is usually avoided by changing the block sources so that they are powered by the same source but that's not gonna work for me.
I'm trying to use a Voltage regulator to limit train speed in stations.
The way I understand it, I'd need to insulate a part of the track longer than the longest car, which the loco would then struggle with.
Any tips?
Thx.
Edited by Tyraforce
Problem resolved. It was caused by something else.
EDIT: PROBLEM NOT RESOLVED
Edited by Tyraforce
On 1/18/2022 at 8:00 PM, cteno4 said:
@Tyraforce Curious what was causing it. It’s always good to hear potential issues out there someone else may run into later.
I figgured out the power bridging problems. What confussed me was that the Glacie Express cars don't have lighting prep while all the other RhB cars do. The lighting prep includes 2 pieces of metal connecting all wheels on each side of the train thus creating a bridge that caused all the jerks while crossing to a block with different voltage.
I suppose when I cut connections to one side of the train, I'll get worse lighting quality but it should get rid of most of the bridging problems.
Could look at putting a capacitor on each side to help with flicker few small tantalium caps across the power strips should help.
