Kamome Posted July 3, 2024 Share Posted July 3, 2024 Nice work. I applied Kato short couplers to my Woki and managed to fit a knuckle to the Deki, although mine is without its buddy. It does leave a slight dilemma as to what to use the other case for. Mine is currently housing my Tomix Shiki, but there’s still space for other stuff. Link to comment
cteno4 Posted July 3, 2024 Author Share Posted July 3, 2024 What dilemma? Buy more trains. jeff Link to comment
disturbman Posted July 4, 2024 Share Posted July 4, 2024 22 hours ago, ED75-775 said: I won’t lie, these MA coupler springs are the worst, because they’re not actually ‘springs’, they’re little pieces of plastic! The annoying part is that they are clear plastic, which can make it a challenge to find them again, but other manufacturers use similar solutions with thin copper stripes and it's not much better as they are very easy to unshape. Link to comment
Welshbloke Posted October 3, 2024 Share Posted October 3, 2024 https://www.instagram.com/p/DAqA7BIoNca/?igsh=MTJ2am9xdDF6NmFyMg== This ancient Minitrix Ivatt 2-6-0 had a tight spot and a click running in reverse, especially annoying as I'd previously bought and fitted a coreless motor/flywheel kit from Tramfabriek. Today's periodic attempt to solve this pinned it down to the quartering (as the coupling rods weren't sitting level). As the rear axle is easiest to get at I started by pulling the crankpins out (after which it ran as well as Minitrix models are supposed to). Rather than leap into trying to shift the wheels on their axle, I noticed that with the crankpins pulled out the holes for them were "out" from the rods by the same amount both sides. Minitrix locos have the driving wheels geared together with the rods as a cosmetic addition, the result being rather like a timing belt or chain on an engine (if one gear is out of time then it won't go well). In this case dropping the rear axle out and refitting it in the right mesh solved the problem. A quick check followed by refitting the crankpins and it's silent. Short version: if you're servicing a Minitrix loco then do not remove the driving wheels! Taking the motor out and giving the chassis a bath in an ultrasonic cleaner or plastic-safe contact cleaner (followed by turning the wheels back and forth to shake the dirt out) will do the job without having to realign everything afterwards. Link to comment
Tonytramman Posted January 22 Share Posted January 22 trying to fix this, gears are binding so looks like I need to get into them! I'm not sure how to split the chassis but I will find a way, most likely looks like prizing it apart... Link to comment
cteno4 Posted January 22 Author Share Posted January 22 Yikes no screws holding the two halves apart? jeff 1 Link to comment
brill27mcb Posted January 22 Share Posted January 22 (edited) Hi Tony, This looks like the Kato super-small Hiroshima LEX 1000-series powered bogie? A ruler next to it in the picture would show how really small it is. How you got it stripped down just to this point would be an interesting series of pictures! I have a number of these models, but I no longer do all-day setups at get-togethers and shows, so I have no idea how durable these amazing drives are in the long run. One bright side to this is that some of the red or blue My Tram basic models can be sourced so cheaply right now (at least into the U.S.) that it's worth it to buy one and think of it as buying two replacement powered bogies! Rich K. Edited January 22 by brill27mcb 1 Link to comment
bc6 Posted January 22 Share Posted January 22 (edited) I got my Tomix track cleaner up and running once again. The track cleaner is at least 10 years old. I converted it to DCC a while back when I was into DCC. I misplaced the parts for DC operations to work with my current DC test track. I found the parts on ebay and finally sat down to do the fix. It took me about 5 minutes and the track cleaner is back in operation. Edited January 23 by bc6 1 Link to comment
Tonytramman Posted January 23 Share Posted January 23 17 hours ago, cteno4 said: Yikes no screws holding the two halves apart? jeff nope, no screws.. Link to comment
Tonytramman Posted January 23 Share Posted January 23 11 hours ago, brill27mcb said: Hi Tony, This looks like the Kato super-small Hiroshima LEX 1000-series powered bogie? A ruler next to it in the picture would show how really small it is. How you got it stripped down just to this point would be an interesting series of pictures! I have a number of these models, but I no longer do all-day setups at get-togethers and shows, so I have no idea how durable these amazing drives are in the long run. One bright side to this is that some of the red or blue My Tram basic models can be sourced so cheaply right now (at least into the U.S.) that it's worth it to buy one and think of it as buying two replacement powered bogies! Rich K. Hi Rich, yes it is the LEX 1000, he picture makes it look much bigger than it is! I haven't thought of doing a how too, the basics are, remove power bogie (cab) end, just pull it apart from main body. remove body, all noted in the instruction sheet, it is after those jobs it gets interesting though. basically though everything comes apart as its all held together with clips, they are small and fiddley. I hadn't thought about the my trams as replacement parts, so might have to think about that if I can't sort it, also thinking about going DCC going forward... Tony Link to comment
Tonytramman Posted January 24 Share Posted January 24 A further pic of the currently disassembled tram to show size and parts, also managed to fix unitram point this morning as it wasn’t throwing properly in one direction on one track. 2 Link to comment
Tonytramman Posted January 24 Share Posted January 24 (edited) turns out they are easy to split, cleaned and re Assembled however still seems to be a short, very strange, they start to run then want to go in the opposite direction! Edit: now fixed. Edited January 24 by Tonytramman 1 Link to comment
cteno4 Posted January 24 Author Share Posted January 24 So how did you split them just slowly pry around wirh a screwdriver? what fixed the odd issue in the end? Motor get flipped on one truck? jeff Link to comment
Tonytramman Posted January 24 Share Posted January 24 Jeff, yeah just ease the two halves apart and voila! Be careful not to lose the clear light insert and gears, speaking of which, I had to remove one from each truck to get it working!! Mist strange but it has solved the issue. I did forget to re insert headlight plastic but that will have to be done another time… Link to comment
john_ibw Posted January 31 Share Posted January 31 Recently, I picked up a used Tomix turntable along with three Tomix roundhouses as part of a bundle. I hadn't had a chance to test it until today, and to my surprise, the turntable couldn’t index properly or align with any of the tracks. The bridge was moving in both directions, and the servo was working on the rare occasions when it did align to a track. Since it was powering up and moving, and everything else seemed fine, I decided to open it up to investigate further. Here are the steps I followed during troubleshooting: I removed the screws on the section plates on both sides of the bridge. Next, I removed the screw located in the center of the bridge between the rails. I gently lifted the bridge off the well and cleaned the pad under the bridge as well as the spring-loaded pins in the well. During my second attempt, after lifting the bridge again, I identified the issue: the contact switch (see the picture with the pencil pointing at it) had come loose. I glued the switch securely back into position and reassembled everything. Thankfully, this solved the issue, and the turntable now works flawlessly! 6 Link to comment
brill27mcb Posted January 31 Share Posted January 31 Glad you got it working again! The pictures of the mechanism are useful to see. Which version of the Tomix turntable is it? (Item 1621, 1631, 1633 etc.) Rich K. 1 Link to comment
john_ibw Posted January 31 Share Posted January 31 1 hour ago, brill27mcb said: Which version of the Tomix turntable is it? (Item 1621, 1631, 1633 etc.) This one is the 1633. Link to comment
john_ibw Posted February 1 Share Posted February 1 I forgot to mention that the contact pad isn’t secured to the base of the bridge with glue or screws. Instead, it’s held in place by two standoffs or pins positioned at a 45-degree angle relative to the line of contact pins. This seems to allow some diagonal movement, likely to compensate for any uneven motion. It’s a clever design, especially considering that the bridge is secured to the well with just one screw, ensuring the pad remains parallel to the base of the well. Interestingly, if you flip the pad over gently, the PCB has markings that identify the connections for each ring. This suggests it might be possible to use an Arduino and directly reference these markings to map the input and output pins for DCC automation. I’m no expert, so I’d love to hear thoughts from others with more experience. From what I can see, all the power and input connections including position data from the switch can be traced. I’m a bit curious to test this out, but I’m hesitant to risk damaging the unit at this point. Link to comment
