Container terminal
Marcin
40 minutes ago, cteno4 said:
Marcin,
so this is going to be for ttrak? If so then interface modules to come out from the main lines into the yards?
No. Slab track line is for standart t-trak.
Edited by Marcin
Just curious what the final setup will be for the container yard lines. Will they connect into the Ttrak mainline in other modules or just in a custom home setup?
Own conception without connection with mainline, but still t-trak 🙂
A couple of junction modules on either end could tie the inner line up to Ttrak inner line, would be fun to use the yard at shows!
