Drunkenclam Posted July 25, 2017 Share Posted July 25, 2017 Ok, Here you go. Inside the box is the position of all of them I think its something to do with the position of the train as it leaves the first trigger sensor Compared to all the other lines. The train almost is on both sensors at the same time compared to the others, As I don't have a manual. I don't know if this is ok. Or causing interference. Compared to the other direction which I don't have any issue with. All the trains are clearly over the first sensor on the crossing as they leave the trigger sensor. In fact in both these pictures. Dispite the fact I had trains stopped on the crossing, as soon as they were clear (both direction) The gates went up. Link to comment
westfalen Posted July 26, 2017 Share Posted July 26, 2017 I had problems with my crossing gates not going up after trains on my T-TRAK modules. What I did to solve the problem was that, since trains run in only one direction on each track was to disconnect the last sensor in the direction of travel. I surmised the problem was a second train tripping the first sensor before the previous had cleared the last and confusing the electronics. This may not be the same as your problem though, I've never used mine with four tracks. 1 Link to comment
kvp Posted July 26, 2017 Share Posted July 26, 2017 I think the curve after the top sensor on the 2nd loop could cause a miscount. This is not a problem as long as the train leaves the sensor before entering the crossing. I would try to move the sensor away from the curve by at least a car's length. Also you did't say if you have tried swapping the cables. 1 Link to comment
Drunkenclam Posted July 26, 2017 Share Posted July 26, 2017 Everything has been swapped round at some point. I spent ages on Sunday. Disconnecting this and that. Plugging in and testing. I'll try moving the sensor. But that will have to wait a bit. Link to comment
Kiha66 Posted July 26, 2017 Share Posted July 26, 2017 Sorry to hear you're having trouble, but cool layout progress! Do you have a pic of the whole thing? Its neat how the camera can pick up the infrared (ultraviolet?) emitters and makes them visible in the pictures. Link to comment
westfalen Posted July 27, 2017 Share Posted July 27, 2017 I just had another look at your photos and had a thought when I noticed your layout was next to a window. Does the crossing operate correctly at night? I have had problems with mine in too much natural sunlight, it seems the infrared detectors don't like it. Link to comment
Drunkenclam Posted July 27, 2017 Share Posted July 27, 2017 I'm working nights at the moment, So I am unable to check for a few day :( But I'll give it a try Link to comment
Drunkenclam Posted August 3, 2017 Share Posted August 3, 2017 Ok moved the sensors by 248mm :D Lucky for me when I got the crossing I ordered some of the extension cables for it as well. Sensor track in their new location (temporary held up by framing packers) Tested and all seems good. Might have to adjust the sensitivity a bit as it seems a little slower to react. But at least now, the crossing resets after the train has cleared, on all tracks and in all directions at any speed. Time for the next stage 1 Link to comment
