My second Japanese layout
ianlaw
Jeff,
The fences are from Casco. They print them on transparent plastic. You need to be carefull with the angle of the lighting to prevent reflections.
JR500,
The hotel is a www.scalescenes.com office building (I actually built it in Z-gauge for my previous layout, but it will do for this background location for the time being). I can highly recommend scalescenes for high quality downloadable card model kits. Most kits are UK outline and I use them extensively on my BR layout. See the off topic photo for an UK example.
The bridge spans are greenmax plastic kits. The piers are card with printed textures.
A sneak preview of things to come. :) I really like japanese trams and because I decided there was insufficient space for a double track tram stop in front of the JR station building (yet to be built) I needed to find another spot. I decided I would run the tram "up the hill" to the pagoda utilizing some of the planned non-scenic area. The pagoda as a main tourist attraction would be a good excuse for a tram terminus and depot. This required some heavy civil engineering in the form of a deep rock cutting and two concrete bridges as I had to pass under the JR line before I could gain height.
I had a bit of spare time on my hands this weekend so I made a platform and shelter for my tram terminus... Just a bit of scrap card, a few textures I had laying around and a little paint. The photos help to improve the model as they show where I need to improve before I install it on the layout, where of course any alterations will be more difficult.
  • Like 10
Done some more work on the tram loop. The aerial view shows the full loop I put in in the area which was designated to be non-scenic. The scenic break will now be where the EPS boards are. The full JR loop and half the tram loop will be hidden. The JR loop wil be partially under a road embankment and partially through hollow buildings.
I'd hoped to eventually put a hakone style railway in this area, so that's now become a slightly non-prototypically routed tram line (through a gorge).
As this routing was an after-thought I cannot put point motors in. You can see one set of points is on a bridge and the underside of the bridge is visible from below (and has been modelled).
  • Like 13
I love the multiple levels and how busy that bridge scene is without looking like a train set.
You're now making me think about another layout...  Only problem is grades since I use B-Trains and they are not grade friendly.  I guess if I kept grades shallow and restricted it for 2 car trams, that might work out okay.  I guess I will see what happens!!
After a little bit of scenic detailing work I did some tram spotting... The 5014 has been motorised and is out and about. I also noticed a new tram lurking in the deep cutting.
  • Like 13
My tram terminus is nearing completion. Just a few minutes here and there gets the job done.
The station building is modelled after the street side of Dogo-Onsen tram station in Matsuyama. It's new name is Horyuji Temple after the pagoda on the hillside.
I really have no excuse for the fact that the three trams and the bus are from different companies... :icon_scratch:
I need to think about some suitable catenary masts now...
Edited by ianlaw
  • Like 15
It's been a while since the last update. I have built a fire station (painted card with plastic roof) and two fire engines just arrived from PlazaJapan. I also used a few items I bought in Japan this summer. The tram depot is slowly taking shape nextdoor...
  • Like 13
Hello,
I'm still around. Just somehow too busy to do much modelling work. Just a small step towards my small tram depot. Using a scalescenes print I started building a shed into the backboard. I noticed that many steam age buildings in Japan have a european style so I hope this looks appropriate.
Edited by ianlaw
  • Like 12
After a few hour's work, more progress. I still need to put up some catenary and the buildings are not yet fixed in place. I'm still considering if I should clad the shed with corrugated iron sheeting. Even after some wife-assisted-google-searches I didn't manage to find any examples of a brick tram shed.
Ian,
Did you scratch build the white with blue roof building next to the shed? Nice little fire station!
Jeff,
Yes, plastic roofing, card walls painted with undiluted quick drying paint. Modelled after an example I found on google maps, just scaled down a little to fit the available space.
Ian.
I finished the tram depot and adjacent tram stop. I covered the shed in corrugated iron as I thought that looked better.
I decided I needed to incorporate a diesel depot on my layout to display some of my locos and kihas. The photo shows its position in the trackplan I posted earlier in this thread (the bottom section of the trackplan). Scalescenes had a suitable stone paper download available and the peco finescale points I needed arrived today. As I'm DC I needed quite some insulated fishplates and solder connections to create enough sections. Anyone know which depot it's modelled after?
Edited by ianlaw
That looks amazing Ian!  I know Kyushu had a few similar stone engine houses during the JNR period.  Most are gone now, but I believe JRK has one preserved at hitoyoshi station for their SL hitoyoshi Joyful train.
