Welshbloke Posted July 28, 2015 Share Posted July 28, 2015 (edited) I've just ordered one of the Kato V13 elevated double track sets, so naturally I'm looking at the station set to go with it. One question though: I'd probably use the track plan they suggest, with one line using 481-15 curves to wrap around an island platform. However, it occurs to me that there should be enough space to add a short headshunt/siding if I replace one of those reverse curves with a #4 turnout and its associated trackwork, leaving me with a track layout which is pretty common in real life. Question is, therefore, whether it's possible to connect a single track viaduct to that end of the station next to the double track viaduct? I can see three slots for S-joiners in the photos of the station deck pieces, but I don't know whether the double track is too wide for this to work? Edited July 28, 2015 by Welshbloke Link to comment
katoftw Posted July 28, 2015 Share Posted July 28, 2015 (edited) yes you can do that. just me mindful of the catenary poles and bases when doing it though, if you are using them. Edited July 28, 2015 by katoftw Link to comment
brill27mcb Posted July 28, 2015 Share Posted July 28, 2015 In our club setups we needed to use 3 single track viaduct pieces, side-by-side, for a length or two. The double-track viaduct pieces' walls stick farther out, so there is not sufficient space to add a single track viaduct piece next to one. You also remove the little end wall piece from the station viaduct base. Rich K. Link to comment
Welshbloke Posted July 29, 2015 Author Share Posted July 29, 2015 (edited) Thanks for that, I think I can see a way to deal with the lack of elbow room if I use two straight single track 248mm viaduct sections and a curved one for the diverging route. Not unrealistic either - there's a similar setup in Cardiff for the line down to the Bay, which usually has a single car DMU shuttling up and down. Edited July 30, 2015 by Welshbloke Link to comment
