Kato 22-013 Power Pack Hyper D
Sascha
It should work for N scale too, as long as you are careful not to turn it up too high. Also it has two direction switches, which is good for a turntable and a mainline but the voltage on them will be the same, so if you want to set different speeds for each train, then you still need two controllers. This controller is very good for H0, since it has a 2 A output, which is way too much for N scale, but good for larger H0 consists with more than one motor.
Grrrr. And I thought I could turn 6 controllers into 3. Well on with the original plan. Thanks!!!
