NanoGauge Drive Unit
chinbeard
You problably mean this:
http://www.youtube.com/watch?v=ANc0U-Um_e0
The nano gauge power unit is much larger than Bandai sized power units, so you can't really fit it into standard shorties. For slightly longer ones, you can use tomix power units. Also, i don't have the heart to tell the guy who made the video, that he put the bogies onto the steam locomotive the wrong way. You supposed to remove two more layers of bricks, so the driving wheel imitations are level with the bogies and sit above the track. Also, he installed the tender bogie plates rotated 90 degrees, which is not only ugly, but makes them run unstable.
ps: The power unit and the bogies could be usable for scratch builders, since you can remove the top connecting block from the bogies and it's possible to install custom (and more realistic) sideframes. The power unit should be strong enough to move 4 cars made out of relatively solid abs, much heavier than a Bandai train.
