Tomix power supply
katoftw
what is the power supply output for a tomix? ie the transformer that plugs into the wall. 100 volts in, but what volts, amps, hertz out?
thanks
HI Kato,
the 5506 uses 110v - 240v 50/60hz 0.36 amp
the 5507 n-600 is also the same. So it works fine in Australia
HI Kato,
Thanks Dave, thats what I wanted to know.
anytime.
do you have any tomix controllers already?
the original run of 5507 did not have a 110 - 240v pack it was 110v only so should check before you buy if thats what you are after.
5506 is better anyway for the constant lighting feature.
