Ken Ford Posted June 16, 2014 Share Posted June 16, 2014 I have several Modemo Kyoto trams on the water and want to do some prework on converting them to DCC. I assume they aren't plug and play? I have no issue with wiring in decoders, but cutting the existing lighting over to DCC might be a challenge. Link to comment
Nick_Burman Posted June 16, 2014 Share Posted June 16, 2014 On 6/16/2014 at 1:59 PM, Ken Ford said: I have several Modemo Kyoto trams on the water and want to do some prework on converting them to DCC. I assume they aren't plug and play? I have no issue with wiring in decoders, but cutting the existing lighting over to DCC might be a challenge. No, the Modemo cars aren't PnP. However converting them to DCC is very simple - the wiring is all exposed and there is lots of space inside. Cheers NB 1 Link to comment
Ken Ford Posted June 30, 2014 Author Share Posted June 30, 2014 I have a Digitrax DZ146 on order to try an install into one of my Mobi621s - I wanted four lighting functions so I can control the headlights and red markers independently without auto reversing. Several of the videos I've seen show the motorman extinguishing the headlight when he enters private ROW and stations. I also have two trailers - I'm thinking the Digitrax TF4 will work for those. Link to comment
katoftw Posted July 1, 2014 Share Posted July 1, 2014 Thanks. Saves me asking the question. Link to comment
Ken Ford Posted July 9, 2014 Author Share Posted July 9, 2014 The Digitrax DZ146 arrived - it will fit under the driveshaft, but it might require moving the weight slightly. I'm considering making a heavier weight out of lead anyways, so I'm not too worried - I can change the shape and size slightly if needed. Link to comment
