Matteo_IT Posted February 27, 2014 Share Posted February 27, 2014 (edited) Hello guys, I received today the Tomix ED 79. I ordered the item HO-146 (two different pantographs)... but, as you can see... the engine is wrong... So, my question is simple: as it seems the bases of pantographs are the same, if the seller provide to supply the correct pantograph, I can simply replace it? The locomotive is the same, then changes only the pantographs, or there are different cosmetic parts between the two versions, then I need for replace the whole locomotive? Many thanks! Edited February 27, 2014 by Matteo_IT Link to comment
bnicolas1987 Posted February 28, 2014 Share Posted February 28, 2014 Hi, It seems that Tomix made also some mistake... I have make the game of the 7 errors with the pictures of Hobby Search and it seems that both locomotives are the same exept the pantograph. So if your seller can privude you a new pantograph, go ahead with this and keep yours as a spare part. See you. Nicolas Link to comment
