Kato 10-1174 (N700A Nozomi) head/tail lights replacement
fgesto
Hi all,
I installed wrong the FL12 decoder, and when I put the train on the track, the lights in the car number 16 stop working and I can see some smoke from under the car. I thought was the decoder so I take it away, but when I put the car again in the track, the lights didn't turn-on. I think that the light board on this car was damaged. Somebody knows if there is a replacement for this light board? Where can I purchase it?
Many thanks !!
Regards,
Fabian
nscalestation
It's been a few months but I was researching this problem after I also had one burn up on me just as you described on a N700Aand saw this post.
In case you have not already found one Plazajapan on ebay sells the Kato DCC decoders including the FL12.
Link to the listing
Guest Closed Account 1
Never burnt a dcc decoder while running, only on the bench. Haha. In fact they saved my models on a weird crossover track set up from melting.
Something else wrong when you see smoke from an N-Gauge train.
There are quite a lot of cheap N scale decoders that lack short and even overload protection. Anything below 5 dollars is usually way too cheap from the engineering point too.
Hahaha Mr Webskipper,
Murphy's Law: a $200 picture tube will protect a 30¢ fuse by blowing first.
Webskipper - one of my favorite lines I said to my father as he was running his American Flyer loco and it was smoking....."Dad, if it's on fire, it's broken!"
Hi all,
Many thanks !!
Regards,
Fabian
What did you end up doing? Those light boards are cheap n easy.
