roadstar_na6 Posted March 10, 2021 Share Posted March 10, 2021 (edited) You can change it in your setting what happens when you click on the thread title. I was confused by it as well when the new software was online as it didn't behave like that before. A quick glance through the settings revealed that it can be changed luckily in the "Content View Behaviour" tab 🙂 Edited March 10, 2021 by roadstar_na6 Link to comment
Madsing Posted December 25, 2021 Share Posted December 25, 2021 I didn't know about this limit, it's the first time I see this message, strange... Link to comment
cteno4 Posted December 25, 2021 Share Posted December 25, 2021 Ok found it, there is a daily limit on reactions. I’ve increased it some. jeff 2 Link to comment
Madsing Posted December 25, 2021 Share Posted December 25, 2021 It works, I could “like” your post. Thanks Jeff. 1 2 Link to comment
miyakoji Posted December 30, 2021 Share Posted December 30, 2021 I hit that limit sometimes too, usually when I haven't visited the forum in several days and then go through all the unread threads that I want to read. Link to comment
cteno4 Posted December 30, 2021 Share Posted December 30, 2021 Yeah I figured some would bump their heads not visiting often and then catching up. jeff Link to comment
Wolf Posted February 8, 2022 Share Posted February 8, 2022 Anyone knows why I cant add a profile picture? I always run into this error ... (image in question added as well) Link to comment
JR East Posted February 8, 2022 Share Posted February 8, 2022 51 minutes ago, Wolf said: Anyone knows why I cant add a profile picture? I always run into this error ... (image in question added as well) Looking to the screenshot, your file is 102 Ko Try to reduce it Link to comment
cteno4 Posted February 8, 2022 Share Posted February 8, 2022 Yes that’s the issue, the default setting for a thumbnail is 0.1mb (you can see that on the upload screen) buried deep in the forum software somewhere. Largest you ever see it is on the member page so pretty tiny so just needs a little file. It’s always presented cropped to a square image as well so crop it if you don’t want the forum software randomly cropping it (I expect to the center). Cheers, jeff Link to comment
Wolf Posted February 9, 2022 Share Posted February 9, 2022 Heya, thank you all, it works now with 99kb (as you can probably see). Its odd tho as it seems to need to be below 100kb as the system states that it calculates 0.1 MB as 102.4 kB, wich I was below and turned to my initial "bug" reporting. Just in case someone wants to change that message. Link to comment
Martijn Meerts Posted February 9, 2022 Author Share Posted February 9, 2022 The file size limit should probably be increased a bit actually. Considering the high resolution screens on phones and some laptops, thumbnails will be getting bigger and bigger. Pretty sure there's a setting for that somewhere, but never looked for it before 🙂 Link to comment
Madsing Posted February 9, 2022 Share Posted February 9, 2022 There must be some confusion between Kilobytes and Kibibytes! https://ozanerhansha.medium.com/kilobytes-vs-kibibytes-d77eb2ff6c2a Link to comment
Martijn Meerts Posted February 9, 2022 Author Share Posted February 9, 2022 I just increased both the max file size and max image size for the profile image. Or at least, I think I did, there's a billion settings, and these things are also per user group 🙂 Link to comment
cteno4 Posted February 9, 2022 Share Posted February 9, 2022 It actually probably set the emoji max file size to 10gb instead! It is a nightmare fiddling with the settings. It’s always a total reeducation swimming around in there each time I do it (usually with long gaps in between) and they change the interface just a bit with each rev! jeff Link to comment
Wolf Posted February 10, 2022 Share Posted February 10, 2022 18 hours ago, Martijn Meerts said: I just increased both the max file size and max image size for the profile image. Or at least, I think I did, there's a billion settings, and these things are also per user group 🙂 Just uploaded Profile Picture new in 250x250 with 140kB, so guess it works. Link to comment
miyakoji Posted November 7, 2022 Share Posted November 7, 2022 There was some text under the username at the left side of each post. Under miyakoji it said 駅員 ekiin, station staff, my ultimate aspiration. Was this removed? Link to comment
cteno4 Posted November 7, 2022 Share Posted November 7, 2022 Miyakoji, You can go into settings on profile and add that to interests that will show up on the left below your avatar image. Go to your profile page and click on “edit profile” in the upper right of the screen. we didn’t delete anything, but on software revs in the past we have had some small bits of data here and there get corrupted or lost. jeff 1 Link to comment
Martijn Meerts Posted November 23, 2022 Author Share Posted November 23, 2022 Since there was some talk about being able to bookmark specific posts in an info thread, I figured I'd post this here. We have the ability to add plugins to the forum software to add certain functionality. A bookmark feature for example is available as a plugin (https://invisioncommunity.com/files/file/8582-bookmarks-black-friday-deal-15/), but there are also various other plugins available (https://invisioncommunity.com/files/category/160-applications-and-plugins/) If there are any plugins that people find interesting, let us know and we can check it out. Note that most of the interesting plugins aren't free, but considering the amount of donations we've been getting, it's quite possible to pick up a couple of plugins. Also, more related to the post where the bookmarking feature was mentioned, there was mention of the old wiki feature we had / some new feature to store informational posts as an article that's easy to find. The forum software has what they call 'Pages', which is essentially just a way to create custom pages which can then be linked from the main menu. I have looked into this before but never really set it up. We could have a look at it again, since it would allow us to for example create an 'Articles' main menu option, and then start copying various posts to those articles. Link to comment
cteno4 Posted November 23, 2022 Share Posted November 23, 2022 Interesting martijn. Bookmarks looks like it’s what was asked for. Maybe we should start a poll on new features like this. Sports betting app could let us bet if trains are late or on time! pages does sound pretty much like the wiki part of the old software. I remember looking at these when we moved software and then promptly forgot about it. It would require some folks to take charge of page(s) to maintain and add to. Maybe each could be cross linked to a discussion page so folks could comment and add ideas for edits/additions later. This would sort of be like our current first post article topics. big thing though is getting some volunteers to help author and also play managing editor on articles over time potentially (list oriented articles need editing). jeff Link to comment
Martijn Meerts Posted November 23, 2022 Author Share Posted November 23, 2022 Yeah, there's actually quite a few interesting plugins, but we've never really looked into them, because we've really only ever used the core functionality. The only issue I have with the plugins, is that you can't really test them before buying. Pages initially was pretty limited, but it looks like over the past few releases they added quite a bit. I'll enable them again at some point, and play around a bit. We could just set up a couple of pages / articles for testing, and then see if some people would be interested in maintaining them. Link to comment
cteno4 Posted November 23, 2022 Share Posted November 23, 2022 Book list and shop lists may be good test pages along with some of sander’s posts. jeff Link to comment
Martijn Meerts Posted November 23, 2022 Author Share Posted November 23, 2022 Yeah, we can do that. I'll probably look into a bit after doing the forum / server update 🙂 Link to comment
Guest Posted December 12, 2022 Share Posted December 12, 2022 Functionality to mute specific threads or people would be useful. Some threads just get derailed and have no interest in seeing them in my unread list. As well as some users post incessantly and I have no interest in seeing their posts. These are two features that seem very common on other forums. Link to comment
railsquid Posted December 12, 2022 Share Posted December 12, 2022 Odd, there certainly used to be a feature for muting/blocking users, can't see any option for it now. Maybe it got switched off during an upgrade? Link to comment
bill937ca Posted December 12, 2022 Share Posted December 12, 2022 (edited) 1 hour ago, railsquid said: Odd, there certainly used to be a feature for muting/blocking users, can't see any option for it now. Maybe it got switched off during an upgrade? Still there. Called Ignore User https://jnsforum.com/community/ignore/ Click on your user name in the top right corner of the page. It is the second option from the bottom. Under the black strip on the Ignore page is a filtered by dropdown. Edited December 13, 2022 by bill937ca 1 Link to comment
