Kato switches
Densha
Yes, as long as it's like the top option in the diagram.
The bottom option will work with regards to the curve, but it'll likely cause issues with wheels picking the points. In case of the lower option, you'll want to add some straight track, or use a double slip, although I'm not sure Kato has those.
A double slip is Engelse wissel in Dutch, right? Kato doesn't have them, unfortunately. That's a big miss in their Unitrack system.
double slip is 'Engelse wissel' yes ;)
I wonder if they're uncommon in Japan, considering Tomix also took a while to get them.
