keitaro Posted July 20, 2011 Share Posted July 20, 2011 Hi all, I want to have a double viaduct track go around a town in a loop but at one point i want to have a single track break off and slope down to ground level. So the trains can come down so I can switch them out with another train. am i right in thinking that having a double track connect to the item listed below then get some single track via ducts to connect and turn out and slope down from the double track http://www.1999.co.jp/eng/10072575 Link to comment
bill937ca Posted July 20, 2011 Share Posted July 20, 2011 Yes, that will work. I've done that before on a layout. You can also make a crossover (single or double) using Double Track Girder Viaduct set Tomix 3067 (blue) or 3068 (green) so both tracks can access the ramp. http://www.1999.co.jp/eng/image/10072750k/50/1 http://www.1999.co.jp/eng/10072751 Link to comment
The_Ghan Posted July 20, 2011 Share Posted July 20, 2011 Quote Hi all, I want to have a double viaduct track go around a town in a loop but at one point i want to have a single track break off and slope down to ground level. So the trains can come down so I can switch them out with another train. am i right in thinking that having a double track connect to the item listed below then get some single track via ducts to connect and turn out and slope down from the double track http://www.1999.co.jp/eng/10072575 Keitaro, Great idea! Are you going to have a second ramp up in the opposite direction or do you intend to reverse consists up the slope? Cheers The_Ghan Link to comment
keitaro Posted July 20, 2011 Author Share Posted July 20, 2011 i'd like to have one on each side but i am not sure it can fit. i seem to be having trouble doing it in anyrail in a custom way Link to comment
Hobby Dreamer Posted July 21, 2011 Share Posted July 21, 2011 Quote Double Track Girder Viaduct set Tomix 3067 (blue) or 3068 (green) Would these be wide enough to hold tram track? Link to comment
bill937ca Posted July 21, 2011 Share Posted July 21, 2011 Quote Quote Double Track Girder Viaduct set Tomix 3067 (blue) or 3068 (green) Would these be wide enough to hold tram track? No, its not. Close but not wide enough. Link to comment
bill937ca Posted July 21, 2011 Share Posted July 21, 2011 Quote i'd like to have one on each side but i am not sure it can fit. i seem to be having trouble doing it in anyrail in a custom way The problem with this is that Anyrail shows you where to place the track, but not the elevated support structures that are necessary to build the elevated track. Link to comment
keitaro Posted July 21, 2011 Author Share Posted July 21, 2011 Quote Quote i'd like to have one on each side but i am not sure it can fit. i seem to be having trouble doing it in anyrail in a custom way The problem with this is that Anyrail shows you where to place the track, but not the elevated support structures that are necessary to build the elevated track. yep so i use normal points and guess but i don't think you can get 2 of those kist to make a double track through the middle and a turn out on each side Link to comment
Hobby Dreamer Posted July 21, 2011 Share Posted July 21, 2011 Quote No, its not. Close but not wide enough. re: Tomix bridges Thanks Bill, I thought I'd elevate the tram track because its too wide for me on the road level. That bridge (and related product) looked ideal. Tomix has some great bridges!! Cheers Rick (sorry to hijack the4 thread) Link to comment
