john_ibw Posted May 31, 2011 Share Posted May 31, 2011 Need help! For the TCS Automatic Operation Unit, can I use a Kato power unit? Or does it require a Tomix one? http://www.1999.co.jp/eng/10040736 Link to comment
bill937ca Posted May 31, 2011 Share Posted May 31, 2011 Only Tomix power units and Tomix track. Link to comment
Guest Closed Account 1 Posted May 31, 2011 Share Posted May 31, 2011 Better setup. This is what I have. AAR3 Advanced Auto Reversing Unit http://www.bakatronics.com/shop/item.aspx?itemid=753 Link to comment
brill27mcb Posted June 1, 2011 Share Posted June 1, 2011 If you are willing to make Frankenstein conversion cables, you can probably supply the Tomix TCS controller from the Kato pack's train power, plus a constant 12 VDC for powering the controller's internal electronics. The variable train power goes to the TCS controller's white connector cable and the constant 12 VDC power goes to the black connector cable. Be sure to get the polarity right on the black connector connection. The white receptacle on the controller is where the train power goes out to the track. Rich K. Link to comment
john_ibw Posted June 1, 2011 Author Share Posted June 1, 2011 Thanks guys! I was checking to see if I can save on buying a Tomix power unit. Considering, that the setup is going to be simple on this project, I won't need AAR3 since it is an overkill for the simple setup I am planning. Link to comment
