Guest Closed Account 1 Posted January 31, 2011 Share Posted January 31, 2011 Anyone have a trick to cleaning off the remaining burrs left on parts from the spruces? I'm using a #11 blade that is curled near the tip like a hockey stick. It helps remove a lot and therefore not much scratching is needed. Link to comment
Bernard Posted January 31, 2011 Share Posted January 31, 2011 After I cut the styrene pieces off the frames with and xacto #11 blade, I use my dremel 1100 drill with a flat sanding wheel set at the lowest speed to sand the burrs off. This is the drill I use: http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=1100 Link to comment
Guest Closed Account 1 Posted February 1, 2011 Share Posted February 1, 2011 What about for the under 1mm diameter Lamps Poles of Kato Diotown? Link to comment
KenS Posted February 1, 2011 Share Posted February 1, 2011 I use a Xuron sprue cutter to leave as little as possible, the a small flat file to remove any excess. Link to comment
cteno4 Posted February 1, 2011 Share Posted February 1, 2011 web, i start with the micromark sprue cutter. was expensive but got it for like $25 on one of their sales. its gone up in price recently unfortunately. it really does clip very flush. http://www.micromark.com/Patented-Cam-Action-Sprue-Cutter,6442.html after that its either the old #11 blades and/or cheap dollar store emery sticks or the mini diamond files. another deburrer i use are these kids of blades. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280419938982&ssPageName=STRK:MEWNX:IT#ht_2610wt_845 you can use them like a chisel and easier to keep from cutting into the piece. also excellent to clean off bits of glue that plop onto the desk surface! you can also get micro ones that are #61 scalpel blades for getting in those tight spaces to shave stuff out. cheers jeff Link to comment
Martijn Meerts Posted February 1, 2011 Share Posted February 1, 2011 A good sprue cutter helps a lot. Also, I usually tend to leave a bit of the sprue on the piece I'm cutting out, and cut it as flush as possible with the sprue cutter after the entire piece is take out of the sprue. Bit more work but it tends to work better. Other than that, just some sanding paper to smooth it out a bit. Some very fine sanding paper and a bit of water works great, as it doesn't mess with the color of the piece. Link to comment
Bernard Posted February 1, 2011 Share Posted February 1, 2011 I use a Xuron sprue cutter to leave as little as possible, the a small flat file to remove any excess. Ooooh, I like it and the price isn't that bad! 1 Link to comment
Kamiyacho Posted February 1, 2011 Share Posted February 1, 2011 I use a Xuron sprue cutter to leave as little as possible, the a small flat file to remove any excess. I use the Xuron as well. Link to comment
cteno4 Posted February 1, 2011 Share Posted February 1, 2011 hmm maybe ill have to look at the xuron next time at curt's. i got the xuron rail nips after a lot of positive reviews and mine sucks to cut small metal rods with the blades deflecting some! i have several other similar nips here that do not deflect at all! perhaps just a bad luck on the draw on my pair... i am ordering the xuron needle nosed pliers as they look to have a very fine point for tiny wire bending, but smaller than the current ones i have i hope. cheers jeff Link to comment
