CaptOblivious Posted February 17, 2011 Share Posted February 17, 2011 Am I reading tha page right? 315mm minimum radius? I guess it makes sense, given the model, but still... Link to comment
clem24 Posted February 18, 2011 Share Posted February 18, 2011 Am I reading tha page right? 315mm minimum radius? I guess it makes sense, given the model, but still... I thought this was standard for Kato Shinkansen ever since the E1 release but I could be wrong. I am sure you could get away with 282mm as well. Link to comment
David Posted February 18, 2011 Share Posted February 18, 2011 Am I reading tha page right? 315mm minimum radius? I guess it makes sense, given the model, but still... I thought this was standard for Kato Shinkansen ever since the E1 release but I could be wrong. I am sure you could get away with 282mm as well. I was under the same impression. My Kato 800 is 315mm too (and you can "get away" with 282mm if you don't mind the coupler stress and unintended leaning into curves). At the end of the day 25m cars do start to look silly (and not just nitpicker silly) on smaller N scale curves. Link to comment
CaptOblivious Posted February 18, 2011 Share Posted February 18, 2011 Ah. I should check my E4 documentation. It runs fine (no leaning or obvious signs of coupler stress) on 280mm radius track, so I assumed that the stated turning radius must have been 282mm. My mistake! Link to comment
Guest Closed Account 1 Posted February 20, 2011 Share Posted February 20, 2011 Yes. You don't want to run on standard 9.75 inch curves. My Kato 800 showed me that. Then again it showed my Ntrak Club just how well it runs with the DT400 throttle maxed out at 99. Whoo hooo! The bullets are crowd pleasers. Looking forward to getting an E5 and E6. Link to comment
Martijn Meerts Posted February 21, 2011 Share Posted February 21, 2011 I've had my Tomix Dr.Yellow run at full speed through some Tomix elevated track sections. It's a good thing there's a wall on those sections, otherwise the Doc would've take a dive towards the floor ;) Running at high speeds, they certainly do make a lot of noise, even the 7-car Dr. Yellow. Link to comment
Guest Closed Account 1 Posted March 4, 2011 Share Posted March 4, 2011 Kato E5 Shinkansen Debut 05 MARCH 2011 http://www.jreast.co.jp/e/aomori/index.html Link to comment
keitaro Posted March 11, 2011 Share Posted March 11, 2011 quick question i was contemplating gettig this was going to get basic set and then the set b 4 car. don't need the 3 car set right. i ca't really handle a full 10 ar set. Link to comment
Guest Closed Account 1 Posted March 11, 2011 Share Posted March 11, 2011 quick question i was contemplating gettig this was going to get basic set and then the set b 4 car. don't need the 3 car set right. i ca't really handle a full 10 ar set. Up to you. Personally, I like running the full trains. Link to comment
KenS Posted March 11, 2011 Share Posted March 11, 2011 quick question i was contemplating gettig this was going to get basic set and then the set b 4 car. don't need the 3 car set right. i ca't really handle a full 10 ar set. You only need the basic set, but you might want to add the three-car "A" set instead of the four-car "B" set, as it appears to add the case for the cars from the basic set (the Japanese version of Kato's page seems to say that anyway). The expansion sets mostly just add unpowered cars. The basic set will have the two cab cars and the motor car (Kato's description confirms the motor and the car numbers for the two cab cars there match the list in the Wikipedia entry) Link to comment
The_Ghan Posted March 11, 2011 Share Posted March 11, 2011 quick question i was contemplating gettig this was going to get basic set and then the set b 4 car. don't need the 3 car set right. i ca't really handle a full 10 ar set. Keitaro, the prototype runs only as a 10 car set, I believe. There are plenty of reasons why you might choose not to run a full prototype. In such a case, I don't think it matters which add-on you choose. Cheers The_Ghan Link to comment
keitaro Posted March 23, 2011 Share Posted March 23, 2011 this ships on fri started to think I should have ordered this than the kiha 91 Oh well bet those who have it on order can't wait till they get to play with it next weekend hah Link to comment
The_Ghan Posted March 23, 2011 Share Posted March 23, 2011 Hey Keitaro, I reckon you'll be able to buy it. There's been plenty of hype surrounding the prototype E5. If it sells out Kato will release it again pretty soon. I hope you manage to pick one up. Cheers The_Ghan Link to comment
keitaro Posted March 23, 2011 Share Posted March 23, 2011 ahh yes would like to but i'm on my last train. For a while. I guess i will pick it up later in the year. Link to comment
Guest Closed Account 1 Posted March 24, 2011 Share Posted March 24, 2011 this ships on fri started to think I should have ordered this than the kiha 91 Oh well bet those who have it on order can't wait till they get to play with it next weekend hah Ships from whom? Link to comment
keitaro Posted March 24, 2011 Share Posted March 24, 2011 released on fri hence should be shipped fri since store would most likely have it already the day before. According to Kato anyway. Link to comment
Martijn Meerts Posted March 24, 2011 Share Posted March 24, 2011 Got mine in the same order as the N700-8000 limited edition as well as the N700-7000 8 car set. The N700-8000 has been in stock for a while, no news on the N700-7000 yet, although it still says March. A shame I won't get my E5 before I leave for Washington, would've been fun running it on the JRM layout there :) Link to comment
Guest Closed Account 1 Posted March 24, 2011 Share Posted March 24, 2011 shame I won't get my E5 before I leave for Washington, would've been fun running it on the JRM layout there :) Send it to me here in AZ. It won't rust while you're away. :) Seriously where did you see it available? Link to comment
Martijn Meerts Posted March 24, 2011 Share Posted March 24, 2011 shame I won't get my E5 before I leave for Washington, would've been fun running it on the JRM layout there :) Send it to me here in AZ. It won't rust while you're away. :) Seriously where did you see it available? I pre-ordered it at HS the day this thread was created.. So it was ordered quite a while ago ;) Link to comment
Guest Closed Account 1 Posted March 24, 2011 Share Posted March 24, 2011 Oh so it goes on reserve for a bit then to email list? Rats I'm on the email list so maybe that'll change tomorrow. Link to comment
Martijn Meerts Posted March 24, 2011 Share Posted March 24, 2011 I'm actually fairly certain Kato will just do an extra run if the E5 is sold out everywhere immediately. It seems to be a rather popular train, so it would make sense for them to manufacture as many of them as they can sell. Of course, chances are Tomix is going to come out with an E5 of their own, and that one will probably have the all-wheel pickup. Link to comment
Guest Closed Account 1 Posted March 25, 2011 Share Posted March 25, 2011 Can someone translate this? Looks like only 10 cars are numbered and 3 sets of 10-858 is needed to reach the 16 car mark. I liked the numbered cars. http://www.katomodels.com/product/assy/pdf_dm/2010-12.pdf Link to comment
Krackel Hopper Posted March 25, 2011 Share Posted March 25, 2011 Looks like only 10 cars are numbered and 3 sets of 10-858 is needed to reach the 16 car mark. I liked the numbered cars. The E5 is a 10 car set.. so I don't think Kato will make numbers any higher than that. Link to comment
Guest Closed Account 1 Posted March 25, 2011 Share Posted March 25, 2011 Oh yeah I see now from the wiki. I see its available on a Japanese site but I cannot seem to register with a site translator. Oh well. I can wait a few days. Link to comment
Martijn Meerts Posted March 25, 2011 Share Posted March 25, 2011 E5 was released today, although HS is sold out already. Guess they (for the moment) only got enough to fill the pre-orders. They did put up some more pictures of the thing on their site already though. Link to comment
