KenS Posted April 28, 2010 Share Posted April 28, 2010 I'd seen that Kato station in a box in the store, but it looks even better than I thought it would. I don't think the platforms look too narrow. Have you thought about what kind of scenery is going to go around it? Village/town center, rural/agricultural fields, or something else? Link to comment
Lawrence Posted April 28, 2010 Share Posted April 28, 2010 Just a quick nitpick: If this is a terminus, isn't the overhead walkway overkill? Well I guess the pax will have to cross the line somehow and it certainly adds to the scene. Will look even better once painted and detailed as you said, very nice little part of the layout Link to comment
Claude_Dreyfus Posted April 28, 2010 Author Share Posted April 28, 2010 I'd seen that Kato station in a box in the store, but it looks even better than I thought it would. I don't think the platforms look too narrow. Have you thought about what kind of scenery is going to go around it? Village/town center, rural/agricultural fields, or something else? These pictures have been taken from the operators side of the layout, obviously meaning that the viewing side will be the side currently facing the wall. The station will be situated in a small town, which will be situated in the area behind the station building. This will be on a slightly higher level and there will be a retaining wall running along the back of the plaform with the fencing, although only to the right of the building as seen in the pictures. The landscape will be 'undulating', with the town being situated within the Japanese Alps. Link to comment
Krackel Hopper Posted April 29, 2010 Share Posted April 29, 2010 hey hey, I like the design so far! It will cost you a small fortune, but WorldCraft is releasing a number of small electric locos. ED501/2, Deki 108s and EF10's.. in blue and brown liveries. Are the Kato rural platforms from the basic (23-130) kit or do you also have the extension set (23-131) added on? I've been looking at this set for possible T-trak applications but with no itemized description of 23-130 I'm still trying to get an idea of how many platforms sections come with that basic package. Jon Link to comment
Claude_Dreyfus Posted May 3, 2010 Author Share Posted May 3, 2010 A successful weekend has just been had. Mrs Dreyfus' brother has come down from the wilds of the North to rebuild our computor, doubling the memory and adding all sorts of flash new technical bits as well as setting up Mrs Dreyfus' new iPhone... Whilst this has been going on, I have been in the shed working on the layout . Firstly the boards were given a good coating of satin black paint..this was left overnight to dry (picture 1)... Today, I set about laying the track, making sure (a) the correct types of fishplates were fitted, and (b) locations were marked out for ther fitting of point motors and wiring. To start with, the cork underlay was layed down. Once I was happy with the location of the station in relation to the front and back of the boards, the underlay was glued into position. Following on from this, the track laying started; making sure we had a correct distance from the platform edges. So far I have completed the station area, as well as the JRE line approach from the fiddleyard. The third sector line platform and approach has also been completed, however the approach is only down as far as the junction for the shed and stabling yard. To complete the yard, I'll probably need another two points, although I should be okay for track. Hopefully this should be complete within the next couple of weeks and then attention will turn to wiring the thing up! In answer to an earlier question about the station, this is made up of three kits; Station Building 23-220; rural station 23-130 and extension 23-131. In addition, the footbridge is 23-224. A number of the sub structures have yet to be built, and there will be a couple of lengths of platform left over. All will need the attention of a paint brush before they are fully completed... 5 Link to comment
Claude_Dreyfus Posted May 30, 2010 Author Share Posted May 30, 2010 At last! After a number of weeks, tracklaying is finally complete...I purchased the final point and couple of lengths of track this morning; not to mention the obligatory fishplates, pins etc. that I always seem to run low on. Drilling has started on the electrical feeds, and the intention is to split the boards over the next week or so to enable wiring to start....the bit I'm dreading! A couple of pictures now: The first shows the newly completed fiddleyard - the four tracks on the right - as well as the stabling sidings for the third-sector line; this also includes stabling for the JRF loco that brings the transfer freight in. The second is another general view, showing the completed trackwork. 1 Link to comment
KenS Posted May 31, 2010 Share Posted May 31, 2010 I'm puzzled by the switch layout in the middle. it would appear that the front two fiddle-yard tracks can access any platform, but the back two fiddle tracks as well as the stabling sidings can only access the rear platform track. That makes sense if you want to treat the two halves of the fiddle yard as representations of two separate lines. But since they are "off stage" in a sense, that seems like an unnecessary limitation. Wouldn't it be better to also have a link from the lead to the rear fiddle tracks to the lead to the front two? You would seem to have room if you moved the stabling connection a bit more towards the center of the boards. That would leave the stabling tracks dedicated to the rear platform, but would allow any platform to be reached from any fiddle track, giving you more flexibility. Is there not enough space, or is there a reason you want to have this limitation in place? Link to comment
Claude_Dreyfus Posted May 31, 2010 Author Share Posted May 31, 2010 Interesting observations regarding the track layout. You are correct in your first comment. Essentially the two fiddle yard tracks to the right serve all platforms; these are the JRE lines. Passenger trains will run directly to the two main platforms, the link to the third is for the freight trains, which changes locos in the branch platform before reversing up the branch line. The remaining two fiddle yard roads are for the third-sector branch, which uses the third platform and is also serviced by the stabling yard - this yard will also be used to stable the JRF loco whilst the freight train is working up the branch. I wanted to keep the two elements distinct and separate, especially in the fiddle yard. This layout is designed for exhibition use, so the restriction is aimed to keep the two sections running independently. I have used a 'shared yard' approach on a previous club layout, where it was serving a main line and branch and it can lead to confusion when operating...perversley I like to throw in limitations when it helps to make operation more interesting. There is also the element of space, or more importantly baseboard design. The layout is constructed on two 4' x 1' 6'' boards, and the joint between the two sections is between the three station throat points and the access to the stabling point. The point locations are governed not only by the joins, but also the baseboard reinforcement braces that run width-ways along the underside of the boards; these obviously preclude the siting of point motors here. There is also the visual element here. I wanted to have some, albeit very small, open track. The two tracks to the fiddle yard will vanish into tunnels just before the fiddle yard points, so there is limited space...I wanted especially to have a section of thrid-sector track; another reason why the entrance to the stabling sidings is a little way off from the station. Hopefully when the scenery starts taking shape it will make a little more sense... Link to comment
harukablue Posted May 31, 2010 Share Posted May 31, 2010 I I wanted to keep the two elements distinct and separate, especially in the fiddle yard. This layout is designed for exhibition use, so the restriction is aimed to keep the two sections running independently. I have used a 'shared yard' approach on a previous club layout, where it was serving a main line and branch and it can lead to confusion when operating...perversley I like to throw in limitations when it helps to make operation more interesting. Great another Japanese layout on the exhibition circuit, I hope to get my small HO depot completed for 2011 Lew Link to comment
Claude_Dreyfus Posted June 1, 2010 Author Share Posted June 1, 2010 I wanted to keep the two elements distinct and separate, especially in the fiddle yard. This layout is designed for exhibition use, so the restriction is aimed to keep the two sections running independently. I have used a 'shared yard' approach on a previous club layout, where it was serving a main line and branch and it can lead to confusion when operating...perversley I like to throw in limitations when it helps to make operation more interesting. Great another Japanese layout on the exhibition circuit, I hope to get my small HO depot completed for 2011 Lew Perhaps the opportunity to post another layout thread on here... Hint hint Link to comment
Claude_Dreyfus Posted June 5, 2010 Author Share Posted June 5, 2010 Today has been spent starting the much dreaded wiring. Essentially all this has involved is drilling lots of holes in the baseboard, feeding wires through and soldiering them to the track. There's not a great deal to do, but some how it took me four hours! I also secured the tracks across the baseboard join and cut the track. Net result of todays activities is a layout that looks no different on the face of it now than it did this morning! However all the droppers are in place, and some sort of wiring diagram will be devised so I can make sense of it all. Picture below is an overall view of the whole layout. Hopefully by adding the stock, you can seen in context the sort of space I have to play with... Link to comment
Bernard Posted June 5, 2010 Share Posted June 5, 2010 Claude - It looks great and I love wiring! It's the "dreaded" scenery I'm not wild about. Link to comment
KenS Posted June 6, 2010 Share Posted June 6, 2010 Net result of todays activities is a layout that looks no different on the face of it now than it did this morning! That seems to be true of half the things that need to be done on a model railroad. I probably dislike scenery work more than electrical work, but it's a close race. Both do have their fun, or at least interesting, aspects. But both seem to consist largely of doing the same thing over and over again, with little to show for it until it all comes together in the end. But that's the payoff: in the end all that work does come together and produce a working railroad. Either that, or a short circuit sets the scenery on fire and the house burns down. Link to comment
scott Posted June 7, 2010 Share Posted June 7, 2010 ...and either way you get an impressive result! Link to comment
Claude_Dreyfus Posted June 7, 2010 Author Share Posted June 7, 2010 Interestingly, it is the scenery I am most looking forward to. I particularly enjoy the more 'artistic' side of modelling... Track-laying is not so bad, but the electrics is a necessary evil that, for me, is to be endured rather than enjoyed... Fortunately the layout is not complicated, deliberately so; I have worked on layouts with more advanced electrics and get thoroughly confused Link to comment
Claude_Dreyfus Posted October 4, 2010 Author Share Posted October 4, 2010 It has been a little while since I last posted on this thread; for a simple reason. Nothing has happened! Until now that is... I have mentioned many times before that I am no fan of wiring. I can do it, but not to a great standard, and as the intention is for this layout to not only be for the long-term, but also for exhibition purposes, I want it to be both durable and reliable. To acheive this, I'm being lazy aned passing it over to a club colleague. By my reckoning, life is too short and a hobby is meant to be enjoyable (I'm rubbish at woodwork, so another couple of club colleagues built the boards), so why spend ages doing soemthing I don't like? ...I spend most of my time doing that at work! Furthermore, better to pass this to someone who loves that sort of thing (their hobby after all), and when we get to the scenic work on his Z Gauge Swiss layout, I'll repay the favour (he likes scenery as much as I like wiring!). So hopefully I'll have a really well wired layout, with a smart control panel, within the next few weeks. Getting excited, as once this is done we can press on with the scenery... Link to comment
Claude_Dreyfus Posted April 22, 2011 Author Share Posted April 22, 2011 It's been quite a while since anything was updated on here...I have even had the 120 days posting notification! Anyway, last Wednesday I took delivery of the layout from its winter break in the neighbouring county, where it has been wired up, as well as having a nice new control box fitted. The layout was set up, plugged in and away we went with playing trains having an operating session. The control box is a flash bit of kit with LEDs indicating the point direction as well as some element of cab control for extra flexibility. Here, the track plan can be seen clearly, along with the two Gaugemaster 'walk-about' controllers. Very simply, the blue switches are for the points, the grey are isolators, the green are touch-release isolators (you have to hold them across to de-isolate these sections), and the yellow are cab control switches, enabling trains to operate from either controller along these sections for extra flexibility. The wiring itself looks pretty neat. I have a few more weeks of playing trains (getting familiar with the controls) before ballasting starts. Still, I was able to run a few things of interest. 3 Link to comment
KenS Posted April 23, 2011 Share Posted April 23, 2011 Nicely done. I built a very simlar set of control boxes for my old HO layout (one box per section, four in all). They worked very well, and were easy to explain to visitors. I'd say you've got a very good foundation to build your railroad now. And playing with trains, I mean testing , before you get to ballasting is a good idea. That way you can be sure the trackwork is solid, and trains run well on it, while it's still easy to rip something out and repair/replace it. Fixing track after ballast and scenery is down is much more work. You could also try making some temporary stand-in buildings out of cardboard and tape, to make sure they don't get in the way (in terms of line of sight or being too close to the track) and that the trains look "right" running through the planned arrangement. I'm a big fan of trying things out before committing to a plan. Link to comment
Bernard Posted April 23, 2011 Share Posted April 23, 2011 Claude - When I saw the 1st photo I thought it was Ken's layout because the wiring is so precise and neat. Very nicely done. I'm also one for testing out track before doing the final touches...the only problem is, one I have trains running it's hard getting back to working on the layout. Link to comment
KenS Posted April 23, 2011 Share Posted April 23, 2011 His wiring is neater than mine. Link to comment
Bernard Posted April 23, 2011 Share Posted April 23, 2011 His wiring is neater than mine. You haven't see mine....and I have diagrams so I don't get lost. Link to comment
Claude_Dreyfus Posted April 28, 2011 Author Share Posted April 28, 2011 My wiring is truely shocking...and borders on the dangerous; hence getting John to do the wiring for me! On a more serious note, many exhibitions now require layouts and their associated equipment to be PAT certified. Althoguh the controllers and extension leads have yet to be tested, the connections and other electrical bits will standup to any scrutiny of this nature. From a scenic point of view, I have roughly cut a piece of high density foam to fit in the area behind the platforms. There is still some grading to be carried out, and the foam has not been fixed down, however this is the sort of height I am looking at. There will be a concrete wall behind the platforms, with the town at a higher level. Any thoughts on height and appearence, bearing in mind that although it is currently uniform, it won't stay that way! Link to comment
angusmclean Posted April 29, 2011 Share Posted April 29, 2011 Claude and others, my following comments are intended not as criticism, but to create an awareness in regards to the use of foam to form hills, buildings or whatever on your layouts. I have been a fire-fighter all my working life, and I have seen just five litres of this stuff smouldering, wreck the complete interior of a multi-storey house, and it didn't do the occupiers lungs much good either, as when we arrived they were coughing up black goo. All walls, ceilings and carpets were coated in thick black soot, when we walked on the blackened carpets, we left clean footprints. A simple guide for safety is not to have any electrical joints or components near the foam, never leave the power on if not in attendance, use plenty of smoke alarms, and shut doors at night. I don't think the hazards associated with using foam are overly risky on a model railway layout, you just need to be aware of the consequences of a malfunction, and take steps to minimise the damage. Angus 4 Link to comment
Claude_Dreyfus Posted April 30, 2011 Author Share Posted April 30, 2011 Thanks for your note of caution Angus. For many, this foam is a fairly new modelling material, and does have exciting potential. I have heard of its successful use as baseboard material. I would, however, assume that it has the same fire resistant properties as polystyrene and your warning that it gives off lots of nasty gasses when burning does not suprise at all. In this case, the layout is stored in a shed beside the house, which has not electrical connections...resulting in a very long extension lead running from the house. Net result here is that when ever the layout is left for any length of time this lead is unplugged. Also, the control panel and many of the 'gubbings' (tranformers, controlers etc.) are separate from the main body of the layout. Although I have not experinced this myself, I have heard tales of layouts overheating and the scenery melting/bursting into flames and it is probably an opportune to time agree that many layouts with their electronics mixed with scenery with flamable paints and other materials are a potential dangerous combination if left unattended whilst plugged in. Link to comment
Mudkip Orange Posted May 1, 2011 Share Posted May 1, 2011 You know awhile back there was an NMDOT Rail Runner that drove right thru a wildfire. With a foam layout and some Athearn stock you can replicate this incident IN SCALE! Link to comment
