bc6 Posted 6 hours ago Author Share Posted 6 hours ago Here are some labels that I made on the P-Touch for the passenger cars. 2 Link to comment
Kingmeow Posted 5 hours ago Share Posted 5 hours ago Next time, do all 10 at once, each separated by a few spaces. Then cut them apart after printing. You will save a lot of wasted leader tape. (Unless that's your desired intention above.) Also, another hint. You can pick smaller fonts or even narrow fonts to make them more narrow in case they are too big for N-scale. 1 Link to comment
bc6 Posted 3 hours ago Author Share Posted 3 hours ago 1 hour ago, Kingmeow said: Next time, do all 10 at once, each separated by a few spaces. Then cut them apart after printing. You will save a lot of wasted leader tape. (Unless that's your desired intention above.) Also, another hint. You can pick smaller fonts or even narrow fonts to make them more narrow in case they are too big for N-scale. Those are good suggestions that I'll use for the next set of labels. Do you know if you can serialize 1-10 with the frame. Hopefully I won't need to shrink the font anymore than what they currently are. I'm 99% sure that they'll fit even with the limited space underneath the E321 hopefully lol. Link to comment
Kingmeow Posted 2 hours ago Share Posted 2 hours ago I remembered reading about serialization in the instruction manual for my unit but I have never tried it. I think it depends on the firmware of your unit if it can do that or not. Check your instruction manual. I *believe* my unit can do it but I have no need as I don't need too many of these at a time. 🙂 Link to comment
bc6 Posted 59 minutes ago Author Share Posted 59 minutes ago Oh ok, I see there's an 800 # 8 may give them a call. Link to comment
