UnfinishedKit Posted Sunday at 01:05 PM Author Share Posted Sunday at 01:05 PM Terrible photo but I’m getting closer to working point blades after a few wrong turns. what I’ve learnt is that there’s no way to get 3D printed stainless steel clean enough to silver braze to or at least no way I was going to. Much more sensible to drill through and braze the rail to a brass rod. Lots more fettling to do. I do think I’m onto something with this high silver content jewelers brazing paste. Perhaps unsurprisingly it makes a much stronger joint than lead free electronic solder if you do it right. Right is very clean and 715C. 1 Link to comment
UnfinishedKit Posted 11 hours ago Author Share Posted 11 hours ago this photo is a little better. The major learning from this run out is that AIA should have printed the railhead a little high so I could grind it back and get a decent surface. 1.2mm instead of 1mm should do the trick Link to comment
