ehtcom Posted August 27, 2024 Author Share Posted August 27, 2024 Took delivery of a small package from Banzai Hobby today. I was able to test the top level layout and made some minor changes for better running. (second half of the video) 1 Link to comment
ehtcom Posted August 27, 2024 Author Share Posted August 27, 2024 I think I'm getting close to a final layout plan. The base has now grown to 1220mm x 810mm (size of the uncut plywood). Please make suggestions. I will point out that I do like a track heavy layout. The bottom level will be a station with two platforms, a single sided and island. It will run three trains with two being controlled by the Tomix 5574. I'll most likely run three 4 car series 0 shinkansen and swap between three the JR 485 series (Tomix 98548) and similar, which I'll collect over time as funds permit. On the 5574, I might try to setup a dead section on both loops in the middle off the tunnel with a variable timer so the trains take extra time to re-appear. The upper level will have small freight and local passenger service (between two small stations), maybe a 2 or 3 car train. Suggestions very welcome. Earle. 3 Link to comment
