bc6 Posted March 12, 2024 Share Posted March 12, 2024 (edited) I have these pretty cool container kits but I'm stumped on a couple of things. Where do the tiny green clamp-looking things go? The clamp things go between two containers to kind of lock them together. Would you permanently install the bottoms onto the container with super glue or PVA glue? Edited March 12, 2024 by bc6 Link to comment
bc6 Posted March 12, 2024 Author Share Posted March 12, 2024 These are the containers. https://www.amiami.com/eng/detail/?gcode=RAIL-30735 Link to comment
cteno4 Posted March 12, 2024 Share Posted March 12, 2024 Interesting little kits. Do you get 5 sets in a pack? as for the clips I guess it’s in how you want to use them. Have you tried to see if the clip into Tomix or Kato kokis? PVA on plastic like this will work unless you give it a sharp bend like you might get fiddling with these and pop off. If you don’t want to use a more permanent cement and try these out try PVA and see if it works well enough for your use, you can always pop/soak off PVA and use something more permanent once you know how you want to use these. i agree with Inobu, I’m always trying to use little magnets when I can, usually an elegant solution when it works. jeff Link to comment
bc6 Posted March 12, 2024 Author Share Posted March 12, 2024 Yes, they came 5 to a pack. The clips are used to connect one container to another container. I'm going to use PVA to secure the bottoms. I'll look for some magnets as another solution. Link to comment
