Glue for PLA print plastic
b.nice2000
I've used Zap-A-Gap in the past, a similar gap filling CA.  Recently switched to Weld-On #16.  This fuses PLA together, like a plastic cement does with styrene.
I coat both surfaces and press the pieces together hard for a few moments.  Excess glue wipes up easily from along the seam.  If not pressed hard together, the joint might pop apart easily.  When it does get a good seal, the joint stays fused.
https://www.amazon.com/dp/B003HNFLMY
