Paro Posted May 14, 2023 Share Posted May 14, 2023 (edited) Hello, About 5 years ago I had a tram setup using Tomix wide tram track. I moved around a lot so have not had it set up since then. I finally am settled and have room to set up again. All of the Tomix tram track I have are straight pieces and various curves. The only way I can see to have a crossover is to use normal track that does not have the "built in look" like all my other pieces. I did see Kato has a great looking crossover piece (Kato N 40-210 Unitram Street Track, Electric Turnout R180mm) so I am wondering if in the past 5 years maybe something has been produced to attach the two products? Thanks for any information. Paro Edited May 14, 2023 by railsquid fix name typo Link to comment
Wolf Posted May 14, 2023 Share Posted May 14, 2023 Hey, You looking for Kato 20-045. Its a short straight regular kato piece you can connect to tomix finetrack pieces. For the tram stuff might force you to build some in beetween out of these. Link to comment
MeTheSwede Posted May 14, 2023 Share Posted May 14, 2023 The separation of the pair of tracks is not the same with Tomix and Kato. The distance between the tracks in a Tomix tram track double track configuation is larger than the distance between tracks in a Kato Unitram double track. Link to comment
brill27mcb Posted May 14, 2023 Share Posted May 14, 2023 Yes, Kato uses a 33mm distance between parallel tracks, whereas Tomix uses 37mm. Also, most of the Unitram track line-up has not been available for years - many people are waiting to see the Unitram double-turnout pieces offered once more. If you can use a hobby razor saw and hobby knife (like X-acto), you can use pieces in the Tomix roadway kit 3079 to "pave" the Tomix mini-points and create other ideas, like the tracks swinging off of the side of the road onto private ballasted right-of-way. The color and texture of the 3079 paving kit (but NOT the earlier 3076 kit) matches the Wide Tram track. In fact, for a simple crossover between two parallel tracks, you do not need to do any cutting, but you will need 2 kits. See https://www.tomytec.co.jp/tomix/report/n/nj_061.htm (shows the older 3076) and http://www.trainweb.org/tomix/ for ideas. If you mean a 90-degree crossing, Tomix does make that in Wide Tram. Rich K. Link to comment
Paro Posted May 15, 2023 Author Share Posted May 15, 2023 Rich K, Thanks for the information. I just ordered the 3079 kit. Paro Link to comment
