bc6 Posted April 16, 2023 Share Posted April 16, 2023 (edited) I'm installing my EM13 and my FL12 decoders in my E235 Yamanote 11 car set and I'm running into problems and could use some help. So my EM13 install went well considering at first I installed the decoder upside down and fixed it the motor unit runs perfectly with my NCE Power Cab system. Now I have red leds on both end cars, Has anyone else experienced this and been able to fix it. I figured out through reading a post on JNS is that you don't push the decoder all the way in the slot (pics attached of proper placement of decoder) Troubleshooting steps I've taken to fix LED issues Make sure the hatch is closed. I've tried to reorient the decoder but the leds are still red. Taking a FL12 out of a end car and seeing how it operates without a decoder (I have red and white lights) Read through the JNS DCC section. I moved onto installing the FL12 in my end cars and nada nothing, I did install the FL12s upside down and shorted out the PCP but it works fine now. (maybe this is where I messed up possibly damaging the decoders) Programming the head motor and end cars with 2026 and still no lights. I put the end car on the track and had a led light up for a second. Resetting the throttle Resetting the decoders Running the motor car with the head and end car (no lights either) Edited April 16, 2023 by bc6 Link to comment
inobu Posted April 16, 2023 Share Posted April 16, 2023 Its a programming issue. Remember one of the decoders is facing backwards. Function setting in the decoder where it sets the direction. Inobu Link to comment
bc6 Posted April 16, 2023 Author Share Posted April 16, 2023 3 hours ago, inobu said: Its a programming issue. Remember one of the decoders is facing backwards. Function setting in the decoder where it sets the direction. Inobu What CV do I need to program. Below is a pic of how the decoders are currently setup. I'm not sure if I mentioned it but the leds are constantly on. Link to comment
inobu Posted April 17, 2023 Share Posted April 17, 2023 Its in CV 29 but here the link that goes through everything. http://www.sumidacrossing.org/ModelTrains/ModelTrainDCC/KatoDCCDecoders/ CV29 Values 6 = 28/128 speed steps, Analog Conversion, Forward direction, 2 digit address 7 = 28/128 speed steps, Analog Conversion, Reverse direction, 2 digit address 38 = 28/128 speed steps, Analog Conversion, Forward direction, 4 digit address 39 = 28/128 speed steps, Analog Conversion, Reverse direction, 4 digit address The NCE Power Cab has a Headlight button as well as the Direction key and F0 Key. Each has it control of the lighting. There might be a difference in what the Power cab does I think. In any case your next step is to get a USB interface and get JMRI going. It will give you a better visual on the programming via a PC. Inobu Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 40 minutes ago, inobu said: Its in CV 29 but here the link that goes through everything. http://www.sumidacrossing.org/ModelTrains/ModelTrainDCC/KatoDCCDecoders/ CV29 Values 6 = 28/128 speed steps, Analog Conversion, Forward direction, 2 digit address 7 = 28/128 speed steps, Analog Conversion, Reverse direction, 2 digit address 38 = 28/128 speed steps, Analog Conversion, Forward direction, 4 digit address 39 = 28/128 speed steps, Analog Conversion, Reverse direction, 4 digit address The NCE Power Cab has a Headlight button as well as the Direction key and F0 Key. Each has it control of the lighting. There might be a difference in what the Power cab does I think. In any case your next step is to get a USB interface and get JMRI going. It will give you a better visual on the programming via a PC. Inobu Thanks Inobu I had a feeling that I would need to get a usb interface lol thanks for the advice. Link to comment
Wolf Posted April 17, 2023 Share Posted April 17, 2023 (edited) 21 hours ago, bc6 said: I've tried to reorient the decoder but the leds are still red. Odd, this always fixed it for me, just turning the decoder around and as such changing the + and - output from the decoder to the LED board. Can someone explain to me why in this case it didnt work? Can you turn the headlights (taillights in your case) off via dcc? Do they switch to white if you run backwards? Added picture of current install on mine. Yours seem to stick out a bit no? Edited April 17, 2023 by Wolf 1 Link to comment
inobu Posted April 17, 2023 Share Posted April 17, 2023 2 hours ago, bc6 said: Thanks Inobu I had a feeling that I would need to get a usb interface lol thanks for the advice. I think you will enjoy that aspect of DCC. You will be able to use your old cell phones as throttles as well. Inobu Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 2 hours ago, Wolf said: Odd, this always fixed it for me, just turning the decoder around and as such changing the + and - output from the decoder to the LED board. Can someone explain to me why in this case it didnt work? Can you turn the headlights (taillights in your case) off via dcc? Do they switch to white if you run backwards? Added picture of current install on mine. Yours seem to stick out a bit no? Thanks for the pics Wolf I will mess around with the placement of the decoders. The lights are constantly on I can't turn them off. The way the decoders are placed are the only way they work. If I push the decoders all the way in they don't stay on and I only get a flicker of activity when the cars are first place on the track. I really do appreciate the pictures they mean a lot. 1 Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 33 minutes ago, inobu said: I think you will enjoy that aspect of DCC. You will be able to use your old cell phones as throttles as well. Inobu Using a tablet for train operations will be nice and I can get to use JMRI. Link to comment
Wolf Posted April 17, 2023 Share Posted April 17, 2023 4 minutes ago, bc6 said: The lights are constantly on I can't turn them off. I would say there is a fault then, at least that basic function should work, regardless align or if it lights red or white. Let us know how you proceeded. Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 (edited) I'm thinking the same thing I have a email that I sent to Kato waiting for a response from them. Edited April 17, 2023 by disturbman unnecessary quote, answering previous message Link to comment
chadbag Posted April 17, 2023 Share Posted April 17, 2023 15 hours ago, inobu said: In any case your next step is to get a USB interface and get JMRI going. It will give you a better visual on the programming via a PC. When I was using an NCE power cab, I was never able to get JMRI with the NCE usb interface working. I was Mac based and it was like 5 years ago. I switched to DR5000 but never did try and get JMRI running again. I will eventually. More interested, personally, in my (slow going) project to make my own SW... But I did try and get JMRI running with the NCE on a Mac 5 years ago and struck out. JMRI mail list was not able to pinpoint the problem and I soon switched to the new command station and didn't care any more. Link to comment
inobu Posted April 17, 2023 Share Posted April 17, 2023 46 minutes ago, chadbag said: When I was using an NCE power cab, I was never able to get JMRI with the NCE usb interface working. I was Mac based and it was like 5 years ago. I switched to DR5000 but never did try and get JMRI running again. I will eventually. More interested, personally, in my (slow going) project to make my own SW... But I did try and get JMRI running with the NCE on a Mac 5 years ago and struck out. JMRI mail list was not able to pinpoint the problem and I soon switched to the new command station and didn't care any more. It works for sure on Windows but you have to make sure that the Firmware is up to date. In some cases you can lock the USB cab id out. Its one of those situation where it works no problem or its a nightmare. I think we talked about it (Using the Power Cab as a Demo) it has its plus factor. Inobu 1 Link to comment
chadbag Posted April 17, 2023 Share Posted April 17, 2023 10 minutes ago, inobu said: I think we talked about it (Using the Power Cab as a Demo) it has its plus factor. I didn't get rid of it -- still have it. Easy way to set up a simple demo track or something, as you said. Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 I just got off the phone with Kato and spoke to a nice guy who gave me some great troubleshooting advice that I'm going to try hopefully tonite. 👍 2 Link to comment
cteno4 Posted April 17, 2023 Share Posted April 17, 2023 Please share when you have time! Nice they answered you. Katousa I assume. jeff 1 Link to comment
bc6 Posted April 17, 2023 Author Share Posted April 17, 2023 Yup Kato USA, Hey even called me back to give me more advice lol. 😃 1 Link to comment
cteno4 Posted April 17, 2023 Share Posted April 17, 2023 Wow that’s great to hear. Katousa kind of ebbs and flows with how interactive they are. jeff Link to comment
bc6 Posted April 18, 2023 Author Share Posted April 18, 2023 Well its official I suck at installing fl12 decoders as I got magic smoke to come out of it. I'm going to look for a company that will install a fl12 for me. I think I'll send the other one to Kato if they allow me to do so. Link to comment
Wolf Posted April 18, 2023 Share Posted April 18, 2023 So sorry to hear. Dont let it get to you, I got my fair share of FL12s burned by sticking them in too less/too much and having them hit contact where they should not. Hope you find a company and after seeing one or two installed in person you can do it again too! 2 Link to comment
bc6 Posted April 18, 2023 Author Share Posted April 18, 2023 Thanks Wolf I had such high hopes to get it working properly but oh well I tried right lol. I'm glad I went through it for the experience of doing it. Now I'm going to let the professionals figure it out. Hopefully it won't be too difficult to find a reputable company that can install a decoder for me. I'm going to start with Kato and go forward. Link to comment
cteno4 Posted April 18, 2023 Share Posted April 18, 2023 Dcc usually requires some blue/magic smoke “oh crap!”s jeff 1 Link to comment
bc6 Posted April 19, 2023 Author Share Posted April 19, 2023 Lol I'm usually good with electronics but not this time I'm going to let someone else deal with this headache. Link to comment
Brett Posted February 11 Share Posted February 11 Hello all,havent posted for awhile but back into it big time.Get ready in future for some pics of my DCC layout But the point of this post is to make a comment about installing FL12 decoders.Troublesome little things,at least for me. The dont seem to like NCE hardware to much and i was at my wits end until i read the first reply in this thread which mention Decoder Pro I have it installed along with jrmi but never used it other than setup to work Well after loading Decoder pro i had finished programming all FL12 in minutes.THANKYOU! So if you have a NCE powercab dont bother ,use JRMI p.s here is a little pic. regards Brett 5 Link to comment
