Need a Drive Through Carhouse?
Model train sttysov番組トレンド has done another kit bash. This time he took a Tomix 4212 Locomotive House cut out the insides and  installed Tomix Wide Tram straights after cutting the Tomix track to 28mm double track spacing to create a drive through carhouse. He also has a truck body on a Moving Bus chassis.
https://www.1999.co.jp/eng/10429060
How he did it.
Thank you for watching. In the case of the cargo terminal, I modified (cut off) the TOMIX wide tram rail and changed the double track spacing to about 28 mm in the past video. I wanted to use this to create a locomotive depot. In the locomotive depot, locomotive depot! Hakaida the TOMIX double track locomotive ~ (closer to destruction than remodeling) Please subscribe to the channel.
