Wolf Posted July 27, 2022 Share Posted July 27, 2022 (edited) Hello everyone, i wanted to share my first hands on on "Woodland Scenics Realistic Water". As a sort of background from me, I never have cast water with regular resin, so it might be some assumptions are simply wrong. As I am in the process of removing some damage from one of the modules that @Sir Madog had garciously given into my care, i was in the need to figure out how to do a little river. As I had planned to use the name giving product at a later time for a planned own modules with rice paddies, i just took what I had (and gave it a testrun in the process). Reasons I picked Realistic Water: - its supposed to cure clear and smoth - it is not a 2 component resin, you just pour and airdry - its supposed to shrink at a minimum Stuff I was aware of that woll annoy tf out me but I used it anyway - its liquid. And I mean like REALLY liquid - it has a harden time of 24-48h - it has a max casting depth of 2-3mm So when using it I can confirm its luiquid as hell. I tried to seal the underlying pebble riverbed with modpodge solutions as good as I could, and still basically the fiest cast completely sipped away inside the pebble stones. A word of advice on pebble riverbeds: the pour will push out A LOT off air bubbles from in beetween the pebbles, and as liquid as it may be, air is not really able to escape. I sat at least an hour there, brushing out with a small wodden pick all air bubbles i could find. Otherwise it hardens slow. VERY slow. A 2mm deep cast will still be wobbly after 24h (carefully with fingerprints when testing!). The upside is, it is indeed curing clear and near polished smoth, wich was exactly what I wanted (crystal clear very calm mountain river). Also, the layers of casting seamlessly connect, i am so far not able to make out a "connection" beetween the layers. Also, as for it to be liquid as hell, even a Fingerprint was not really an issue to "cover up" There is one thing adverted that I do not feel its living up to, and that is shrinking. Its advertised as "minimal shrinkage" and I hoped with a few casts to be done, but on a 2mm pour i would guess shrinkage to be at least half a mm up to 1mm. This might again be the pebbles "eating" some material, but i would advice anyone not to bet on the shrinking part. All summarised it got the job done perfectly. I didnt use tints, but its supposed to work well with them. As I read about resin heating up, and fuming, and having a little daughter running around, I would probably always go back to this product instead, although the price to pay is the time consuming process. Hope this little summary will be of help to someone, I had fun trying it out, and am happy the Module is restored to glory. Edited July 27, 2022 by Wolf Attached Pictures 5 Link to comment
Tony Galiani Posted July 27, 2022 Share Posted July 27, 2022 I see you avoided the mistake I made - it looks like you have sealed the ends well. I tried this water and thought I had done a good job of sealing the ends but I guess not. I ended up with very little water on the layout and quite a bit on my workbench! Ciao, Tony Galiani 1 Link to comment
Sir Madog Posted July 27, 2022 Share Posted July 27, 2022 I found out how liquid that stuff is the hard way - after it started dripping on the carpeted floor. Needless to say I got some choice words from SWMBO! Next time I used silicone sealant. This was the result: 3 Link to comment
cteno4 Posted July 27, 2022 Share Posted July 27, 2022 Silicone sealant for sealing the ends of the pour or sealant for the water? jeff Link to comment
Sir Madog Posted July 28, 2022 Share Posted July 28, 2022 9 hours ago, cteno4 said: Silicone sealant for sealing the ends of the pour or sealant for the water? jeff The ends of the pour! 1 Link to comment
Wolf Posted July 28, 2022 Author Share Posted July 28, 2022 (edited) Just quick update on the shrinking: The shrinking is bad. Its far more than expected from the advertiesement. It would probably be fine on a flat surface where all shrinks evenly, or if you would now add waves on top (where it actually would do nice as a sort of actually wanted effect), but as i wanted silent, clear water, it leaves a bit to be desired. It still looks great, just does not work out as an even, mirror'ish surface. Edited July 28, 2022 by Wolf Added finished Picture 2 Link to comment
Sir Madog Posted July 28, 2022 Share Posted July 28, 2022 6 hours ago, Wolf said: It still looks great, just does not work out as an even, mirror'ish surface. That matches my own experience. That stuff is OK for a rock-filled stream or creek, but not for lakes or sea shore applications. I used high-gloss varnish for this in previous layouts. 1 Link to comment
marknewton Posted July 28, 2022 Share Posted July 28, 2022 Wolf and Ulrich, that's an attractive scene on the module. You've both done a nice job on it. All the best, Mark. 2 Link to comment
