drt7uk Posted August 26, 2021 Share Posted August 26, 2021 Hi folks, I'm in the process of building a new layout. Because of the size constraints, one set of sidings will be far away from my Kato controllers and switches (further than they were before). Thus I have to choose between buying a number of additional new Kato 24-841 turnout extension cables (costly), or making up the difference by using the 0.5mm / 11amp twin core cable that I'm using for a bus wire and soldering it on (i.e. creating my own extension cable). I have two questions, excuse my ignorance: 1. Will the 0.5mm / 11amp twin cable be OK? I don't want to spoil the turnout switches by overpowering them, or underpowering them. I can't see anything online that says whether Kato 24-841 is 0.5mm, 1mm etc, or the max amp etc. 2. Any idea what the plastic connectors are called? I want to see if I can buy some at a DIY store or online, so I can connect to my existing extension cables. (See image below). Many thanks in advance, David Link to comment
bill937ca Posted August 26, 2021 Share Posted August 26, 2021 They are called Tamiya connectors. Here is an article from a good source: https://quinntopia.blogspot.com/2009/02/unitrack-connectors.html 1 Link to comment
Kiha66 Posted August 26, 2021 Share Posted August 26, 2021 (edited) I've done similar to what you're suggesting by cutting a kato cable and soldering in extra wire length. I haven't had any ill effects from doing it, and it's pretty quick and easy to do. As long as you're using a switch controller that works with kato switches, the length of wire shouldn't be a problem unless there's excessive power drop over the length of the the run. 11 amp cable should more than handle this. Edited August 26, 2021 by Kiha66 1 Link to comment
bill937ca Posted August 26, 2021 Share Posted August 26, 2021 A previous thread on Tamiya connectors. A source I have bookmarked. https://www.componentshop.co.uk/leads-and-connectors/leads/mini-tamiya-lead.html 1 Link to comment
inobu Posted August 26, 2021 Share Posted August 26, 2021 Those connectors are for convenience. I cut them and use terminal blocks. Hobby Lobby Hook up wire. 24 Feet. $5 Quick Spring Connector $9 68 pieces 1 Link to comment
drt7uk Posted August 26, 2021 Author Share Posted August 26, 2021 3 hours ago, Kiha66 said: I've done similar to what you're suggesting by cutting a kato cable and soldering in extra wire length. I haven't had any ill effects from doing it, and it's pretty quick and easy to do. As long as you're using a switch controller that works with kato switches, the length of wire shouldn't be a problem unless there's excessive power drop over the length of the the run. 11 amp cable should more than handle this. Thank you! I've found some on eBay so I'll see if they fit my Kato ones OK and go from there. Of course another option would be just to extend my existing Kato cable by cutting the wire in half, soldering in a longer middle! Will have a think... 1 Link to comment
katoftw Posted August 26, 2021 Share Posted August 26, 2021 (edited) I have cut most my cables in half and used the same connectors. I can go kato to kato, kato to tomix, tomix to kato and tomix to tomix for versatility. Pick whichever works for you. You can then make any length extender you wish. Edited August 26, 2021 by katoftw 1 Link to comment
Sheffie Posted August 27, 2021 Share Posted August 27, 2021 (edited) I think I cut all of my wires in half. I’ve connected my extension wires with screw-in terminal blocks that look fairly similar to what Inobu posted. I’ve never had any trouble. If in doubt use a heavier wire. It can’t hurt, electrically. Edited August 27, 2021 by Sheffie 1 Link to comment
Kamome Posted August 27, 2021 Share Posted August 27, 2021 Remember the cable extenders along with the majority of Kato products are designed with temporary setups in mind. If you are making a permanent layout, things like this are negated. 1 Link to comment
